after installing my short shifter i noticed theres was a loud winding noise i discovered that the bottom rubber bout had cracked and split almost in 2!!! i called nissan and they said the winding noise is normal that rubber boot that cracked acted as a sound deadener. my prob is i can buy a new one from nissan for $21 but it doesnt fit over the short shifter kit!! does anyone know any other way of deadening the sound?? cheers.
https://www.sau.com.au/forums/topic/146044-winding-noise/
The nissan rubber boot when new will slide over the stock stick with a bit of lubrication. Unless your shifter is more than an inch or so in diameter you wont have a problem
And the whine is due to the shifter, not the boot being split. The stock stick is rubber filled so damps it, most after market shifters are solid metal so transmit the noise.
https://www.sau.com.au/forums/topic/146044-winding-noise/#findComment-2738833
mmm so its the shifter itself is it damn well i noticed that when i put the rubber boot over it dampened the noice quite a bit even though it was still there alil. yeh its an ebay lol im poor lol my only prob is it doesnt fit over the sqaure bit that holds the shifter down!! cheers
https://www.sau.com.au/forums/topic/146044-winding-noise/#findComment-2739946
  • 8 months later...
I streched mine rubber boot over the square bit and wraped a cable tie around it to hold it!.......Mine wines a little so I will see how it goes for a few weeks, if it pisses me off I will replace with the standard shifter again.
but when you have a 3.5 inch exhaust noise really isn't an issue!
https://www.sau.com.au/forums/topic/146044-winding-noise/#findComment-3319694
that might be why you've come across issues dude, my nismo one is pretty much perfect
https://www.sau.com.au/forums/topic/146044-winding-noise/#findComment-3319805
i've installed an ebay one before and i noticed that if you put the bottom moon plates on upside down it clamps the gear stick up hard and you get the wine. flip them up the other way and the square plate does up tight but doesn't clamp the shifter up hard, just enough (about 0.5mm to 1mm clearance between the square plate and the top of the box), and you then get no wine. can you spin the square bit around with your hand or is it locked up tight?
https://www.sau.com.au/forums/topic/146044-winding-noise/#findComment-3320459
  • 9 months later...
After installing my short shifter from ebay using the items provided (which I werent happy with) I decided to change things up.
Firstly, the plastic coupling provided that goes around the ball down the bottom of the shifter was gay. I was easy to pull off and put on with your fingers (so if it's that easy, itll drop into your gearbox and do damage). So I went to Nissan Genuine parts and bought a brand new, original bit. this costed me $12. Its much thicker, slightly bigger, and tighter to get the ball in. THIS IS GOOD! I used a mallet to wack it on! then re installed it into my car, and YES! It was difficult to get into the gear box! yay! That means its nice and tight. Now I get NO play when in gear! It clicks in, and stays there!
Also the socket head bolts provided were too f**king small! I made a trip to Bunno's and got the same bolts but longer... and silver haha... I clamped the square bit on with EASE this time, and tightened it just enough, so it wasnt straining. Unlike the new longer bolts, I could only use 2 threads to tighten it, not smart at all. Locked up real tight (Thats why I only drove to work and back, then started working on the shifter again to refine it). I didnt want the vibration or anything like that to drive these bolts out.
Now the whining sound? I couldnt fit my original sound deadener boot around the gearbox and stick because there is a big square plate! So I just sat it there anyway, and put the rest of the boots over it.. I cant hear a sound now! It's probably due to the mixture of the new bolts, and plastic coupling.
Now, it clicks into gear, STAYS in gear, not tight and strenuous, and pretty much perfect.. I can't hear any whine as well :D
Thats my experience with the short shifter kit.
Edited by SinistR33
https://www.sau.com.au/forums/topic/146044-winding-noise/#findComment-3956251
Now, it clicks into gear, STAYS in gear, not tight and strenuous, and pretty much perfect.. I can't hear any whine as well :geek:
That sounds like an awfull lot of effort and something that a nismo or such short shifter would have prevented.... Realy do have to ask yourself what your time and effort is worth....
https://www.sau.com.au/forums/topic/146044-winding-noise/#findComment-3957180
Does different gear knobs contribute to the whining sound of the gearbox? I got this chunky isotta drake knob, and it seems to me like it amplifies the sound! but my metal Trust knob doesnt seem to do it... :S
https://www.sau.com.au/forums/topic/146044-winding-noise/#findComment-3958483
i chopped the top half of my short shifter off about 1 inch from ball, done the same to my original one and re welded the original one on the short shifter. (pressure welder at work tig welded it). now it has the rubber bush on it, it feels and sounds(or no sound) like a standard shifter with a short throw.
https://www.sau.com.au/forums/topic/146044-winding-noise/#findComment-3961770
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
