hi guys,
my mate has a microtech LT-12s with plug and play for his R33, he is getting rid of it due top selling the car. However, i want to take it off his hands....but can this unit fit my rb20det? is the loom different? etc?
what would i need to make it...diff wiring loom? etc?
also what kind of price second hand should they be going for?
THANKS GUYS
https://www.sau.com.au/forums/topic/146048-which-microtech/
you will need to swap two injector wires over (might even be able to do it in the software).
because the LT12S is full sequential you will have to change them, if you run group injection you will not even have to do that, but lose the benefit of full sequential.
look in the powerFC FAQ and its the same injectors you have to swap as you do when you use the Rb25 PowerFC on the RB20.
i can look it up if you get stuck, but yes, it will work on the RB20DET with a small wiring mod.
https://www.sau.com.au/forums/topic/146048-which-microtech/#findComment-2727839
Yeah you'll need to swap the wires. Injectors #4 and #6 are switched between RB20 and RB25.
Is it the guy who wouldn't do COD to me?
Its worth $1250 for the unit, about $250 for the plug. Thats a little cheaper than retail, but thats what you can get stuff for if you shop around.
So second hand, $1100 is a good price... just not good enough that I'll deposit it into a randoms account before I see some goods, lol.
One issue I'm worried about with the plug in option, is loss of HICAS and A/C control etc. If you wire it in yourself using the loom, you can let the microtech control injectors and ignition, with inputs from TPS, CAS, water temp and MAP, then let the stock do the rest.
If you remove the stock ECU completely... your microtech will have to take care of the other stuff. Hit your tuner up about that one.
https://www.sau.com.au/forums/topic/146048-which-microtech/#findComment-2728067
Its two wires.... which you just swap over... I think thats easier than sending back to microtech...
anyway, can you tell us more about the microtech's ability to take care of things like AC and HICAS when the stock ECU is removed completely? Or doesn't the stock ECU effect these things??
https://www.sau.com.au/forums/topic/146048-which-microtech/#findComment-2728938
the microtech contols the air con or idle air & stuff like thermos etc
you can also run a 2 step off it
but you will need to let microtech know when you order to customize it
https://www.sau.com.au/forums/topic/146048-which-microtech/#findComment-2731318
Thanks mate. I'm currently after a second hand one, so I guess I'll just assume that if someone else was running it in a street car and have no idea what I'm talking about when I ask how they controlled their a/c and shit... they probably had it all taken care of by the tuner and its already been sorted.
Just not keen to grab a plug and play, then suddenly get stalling problems when I use the A/C.
Almost seems like cheating just plugging it in, lol, I'm excited.
https://www.sau.com.au/forums/topic/146048-which-microtech/#findComment-2731833
    • Hey guys I have a 2001 Nissan stagea vq25det, I don't have any engine lights and not really any issues running but I was curious to see if I could use my obd II scanner to find anything that was hidden and I plugged my scanner in and it just said "Low voltage cannot scan" does anyone know how to fix this or what this could be?
    • Sadly we have something in common, our Skyline's like blowing up electrically 馃槩
    • So, no videos, but, the FAB9 Elite manifold and 68mm Bosch throttle bodies are in stock, but, not the rear part of the air box The FAB9 rear airbox thingie is made with a 3" intake pipe, to suit the 3" intake pipe size of a 68mm throttle body  When they get some more in stock is currently unknown as I'm waiting for FAB9 to reply with a ETA on resupply, my assumption is they outsource their plastic printing stuff to "china", and with the current "tariff war" going on in 'Merica it could be on hold for an undisclosed time Should I pull the pin on the Intake and throttle body, and wait for the airbox?????, that's what I'm thinking... 1. Would the standard 2.75" OEM intake on the air box really be that much of a restriction compared to the 3" naturally aspirated?????? 2. If I don't get the 3" FAB9 airbox fitted at the same time as the intake and throttle body will it need a retune, when/if it eventually turns up?????? As I'm impulsive, to a fault, decisions will be made within....."what's the time now"???....let's say 12 hours......LOL
    • yeah its just so expensive nowadays and its easy to lose motivation very quickly when you start adding up the costs. I acquired the car from a collector in Melbourne and was lucky to get the opportunity to buy something already completed.  I looked at a proper resto and your paying over 300-400K for a proper one (nut and bolt) so this one to me seemed like a much better option! Car is in private storage and for serious buyers, welcome to come see it/drive it in person (photos don't do it justice).
