Ok so i just completed the MOST BUDGET RB25 conversion in the history of skylines (prob not true)
I thought there may have been a problem because the way i was doing it because the guy wouldnt run after it was mechanically finished.
There was talk of INJECTOR RESISTANCE and CAS compatibility but none of that was an issue.
Turns out the Injectors were seized from sitting around to long.
So my conversion cost me:
$700 RB25DE
$20 to have oil drain welded on to sump
$150 in fluids
$200 for 25DET injectors
Total Cost $1070 RB25 Conversion
Parts I used
RB25 Long Motor
RB20 Gearbox
RB20 Clutch/Flywheel/pressureplate
RB20 PS pump
RB20 Alternator
RB20 Loom
RB20 ECU
RB25 turbo injectors
RB20 Turbo and ex Manifold
RB20 radiator
As you all know, RB25det's have NVCS and i will have to go to Jaycar and buy a RPM based switch (maybe a shift light kit) to control the NVCS.
So there we are people, dont be content with your RB20's lack of torque of throttle response. next time you throw a rod, seek out a $1000 RB25 conversion.
https://www.sau.com.au/forums/topic/146057-got-her-running-finally/
sorry for the stupid questions but im not sure on a few things and am keen to learn about this coz im interested in doing this conversion.
first of all, what is the difference between a long motor and a short motor? does it refer to whether the internals are included with it?
was there any modification needed to fit up the RB20 ex manifold and turbo on? also, did u have to alter the compression ratio aswell?
one last question, did the RB20 loom match straight with the RB25 loom, or did u have to rewire it?
Thanks heaps
Stephen
So you did all the labour yourself? Thats cool but not many ppl can do the whole thing themselves.
Also you are running the std RB20 ECU on a high compression RB25DE with different injectors ( you didnt mention a head gasket)? How does it run?
Also, you havent mentioned the de-gas or re-gas of the air con, are you still running air con?
Im all for doing the conversion, but how good is the finished result? I imagine to get it running reasonably well its going to cost you at least that amount again.???
Very interested in the results and the power it makes. Curious to know if all the talk of the better flowing head actually means it makes more power with the std Rb20 turbo. Expect it to make more power earlier int eh rev range courtesy of higher compression, head design and displacement.But will peak power be any different?
Good luck with it
Stephen, long motor comes with accessories bolted onto it. Pretty much a complete motor.
Short motor is usually the head, block, manifolds... just the actual motor itself. No A/C, no power steering, no alternator....
Stephen: The RB20 Manifold and Turbo bolted straight on with no modifications. I havent modified (dropped) the compression ratio as i feel that any detonation associated with turbocharging this motor can be easily overcome by adding fuel and/or pulling out timing. As for the loom, the RB20 loom was fine for the RB25 save for the soldering of the 6 injector plugs. The RB25 side feed injectors (turbo and NA) use a different plug (generic side feed nippon denso). They were soldered, and insulated onto the RB20 loom. One thing that will pose a problem is that the RB20 loom/ecu has no provisions for controlling the NVCS (which is the variable cam timing on the inlet cam). I can overcome this in a few different ways. PM for details.
Roy: Yeah i did all the labour myself. I cant justify letting a workshop procrastinate on my car for 3 months making excuses all the way like; "we are just waiting on this part"
The CR is standard... 180psi in all 6 cylinders. No metal HG required. It runs RB25DET injectors which are 370cc. I thought it would be too rich, but it seems to be fine.
I never got an AC compressor or condenser with the car when i bought it... some stupid drifter wannabe had removed it. I will be retrofitting it for my driving pleasure.
I anticipate around 170rwkw with a low boost setting. I will have the stock ecu remapped and post results. I fully anticipate this turbo running out of flow around the 6000 mark. The upside to this is it will prob make full boost earlier.
Randy: The motor was technically a long motor, but it was minus alternator, PS pump, brackets, coils, loom.
Sinistagtst: Suck my balls, when you've put in as much effort into an engine swap like this, then you can critise me.
Marki Mark: It idles smoothely but it has not been street tested yet as i havent located any R33 radiator hoses yet and i work 6 days a week!
Andy, nice work!
I done the same thing recently but used a GT3071R running 1 bar.
Im very interested to see how much timing you are able to feed into it before it pings.
Any idea when you will get the tuning side of things done?
ill get a RB25 turbo when one comes up cheap, or get a sliding performance turbo.
i have ordered brand spankers top and bottom radiator hoses for it so add $100 to the cost. They are the last thing before its ready to drift.
ill post results, timing and drivability.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
