  • Replies 48
R32 weight is 1480kg, R33 1520 and R34 1540(just the plain GTR models)
well according to my hpi mag
but the new hsv GTS commo's(6.0L) do 0-100kmph in 4.9 secs apparently, thats a lil scary for a standard V8
Edited by Turbz_13
v spec r34 have another 20kgs! i don't know what from but i'm guessing the front air splitter!
yeah under 5 sec to 100kph is pretty good for v8's because imagine the 3rd or 4th gear accelleration!
i would imagine 100 in 2nd gear
my mates GTR does like 120 in 2nd maybee more i sumtime forget the actual performance of hi car
Lol my Mum drives a Vt V8 commy, so yeh i reckon its a laugh all these tough guys in thre V8 commodores when my mum drives one lol (and no she isnt some big fat bogan either lol)
My uncle has a VT II 250i Manual Clubsport I think it is.
It goes ok does awesome no brake burnouts due to its long first gear but really it doesn't go that hard, first time I drove it I was massively disappointed. I've had a few plays with it and it is rather slow compared to mine.
But its stock, mine isn't.
The LS1's do go pretty damn hard with a few mods. I'm sure Chops's Calais will shock the hell out of a lot of us rwd boys. :)
4wd vs rwd.. well its takes a LOT of power to catch and pass a car that has accelerated fast at low speed even if the 4wd is down 100-150rwkw.
and don't forget average power. Its like comparing a 200rwkw rb20 to a 200rwkw rb25. Or even better a 200rwkw rb25 to a 200rwkw rb30. :)
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
