hey all my car is running like crap and i dont know y it runs worse on a cold night than a hot day its running stock boost 6 or 7 psi flat. the other night i put my foot to the floor and it sounded like it was boosting but it wasnt going anywhere felt like it lost all its power it still revs up to the limiter but if i back off to about 1/4 throttle it just takes off and goes great and i have no idea y i have the usual mods FMIC (gktech) pod filter turbo back zorst and a gutted cat any help would be great thanks
https://www.sau.com.au/forums/topic/146077-help-needed-cars-running-like-crap/
yeah iv got boost gauge thats y i know its always at 6 psi it never goes over it and i checked my plugs they look like there ngk iridium gapped to .8 there so i dont think its them i have no idea what it could be i dont see y it would go into r+r mode with stock boost
its a greddy boost guage and its sits just under .5 bar so 6 or 7 psi y do u think there is something wrong there i thought that was about how many psi they mad standard and y do u think its going into r+r then what do u think would be causing it
hey there,
This explains perfectly what my car does sometimes.
I've changed coil packs and afm to no avail.
Could it be o2 sensor?
I can't seem to find any more info on this - i tried searching but didnt get very far.
any help would be great, thanks
bobby.
hey there,
bobby.
:wave:
If you search with:
+rich +retard
you'll come up with a million threads
I had a very similar problem to yours, it was an air leak, check all your hoses!
i had a tiny crack in one of my rubber hoses (10cm hose and it was not hitting full boost at all even when i floored it, replaced it with a new hose and worked perfectly, boost was just as it had been before! try that...
hey there
lol im not sure about o2 sensors or the wastegate actuator but what i've experienced and stuff i'd jus say...
go ebay ... or ask sau ppl
... n get a used ecu for your car..perhaps 50 bucks?
or ask your mates to lend you one,n if your car works better then it was the ecu, if not forward on to mechanical parts but dun waste ur time on rich n retard its a bitch to deal with it...
  • 1 year later...
Hey all,
In my case this problem was solved by taking apart my ECU, and resoldering all the joints for the connectors to the loom. This isn't a job for the amateur, you are dealing with a very sensitive precision device here...
In my opinion, the manufacturer was fairly stingy on the amount of solder used for these important connectors and they are susceptible to cracking thus causing bad or intermittent connections, or altering the amount of resistance measured in the case of sensors.
Since doing this a few months ago, my car has not repeated this annoying 'rich+retard' mode.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
