Originally posted by KILLER-T
I think it was bad tuning that cost me my last engine it cracked a piston ringland and cost about 5.5k to rebuild and before anyone asks who did the tune i wont tell because im not 100%sure if it was the tuning
Adam,
Out of interest, what were the symptoms of your broken ringland? Was it a major failure that was obvious (bang, smoke, noises that shouldn't be there etc) or a gradual thing? I'm guessing there was audible detonation?
Cheers,
Matt
Guest KILLER-T
Hi whatsisname i had no warning didnt hear any pinging had it on a dyno for a tune up drove it home got up in the morning poped the hood and i noticed oil had been spraying out the BOV and boost solinoid .Took the car for a drive it still had heaps of power. So i took the car to PSI performance and he tested the comp ratios and thats when i was told the bad news that i needed a rebuild
Good to see all is well now mate (many $$$ later).
So on the pre "bad news" test drive did it make any nasty noises? Anything else (other than the oil out the BOV & solenoid)?
Thought it'd be a good idea to get a bit of this kinda' info on the forum, for future reference.
    • This is lower price now given apparently nobody wants these or needs them. It's 550 but if someone sees it on SAU and wants to make an offer, please do so.
    • LS is a good motor, but it hurts my soul when I see it in a RB. Guess it fixes the oiling issues lol.
    • I'm confused. Does this qualify as "Gregging" or are you somehow avoiding the Gregging?
    • More assembly going on, with all sorts of "bolt right on bro" scenarios going on here. Smartly, PTV clearance was checked. And I say smartly because it turns out that the intake was 0.009" from piston meeting valve. This is 0.23mm. This is very not okay. A fast meeting was facilitated between engine builder in Australia and engine builder in the USA which was actually incredibly helpful and constructive actually, various ideas thrown around to get around this issue including: 1) Retard the cam timing which would have brought the exhaust valve closer to meeting piston (it was 0.065") which was uncomfortably close to begin with, and change the cam profile making it 'laggier' 2) Much larger head gaskets which would reduce compression, but half the point of this was to increase compression. 3) New set of pistons ($$$$$$$$$$$$$$$$$) 4) All of the above 5) Get ghetto The concept is you get sticky sandpaper and stick it back to a valve, slightly larger than the valve you/I'm using, like say from a LS3/rectangle port head. You now have a very super advanced flycutting tool to modify your pistons in your block. Then you install it in your head, and attach the other end of the head to a drill. Then you just replicate your valve smashing into a piston with your spinning drill.   This is the result. Repeat many times. It is strongly recommended you have some kind of fixed stop when doing this for extremely obvious reasons because if you press too hard then you're well into apocalyptic repercussion land. The minimum clearance on the intake valve is now 0.075" this is still in the "Too close to be really comfortable" and into "It should be fine" land. Supposedly in the real world the clearances will be slightly bigger. Guess this is what happens when people push envelopes for N/A engines instead of adding boost! Time to move onto the new, upgraded, higher ratio roller rockers from Yellaterra, all tapped and threaded with a stronger bolt for better stability. Very nice. Lets see how they fit. For f**ks sake. Time to bring the grinder out for these aftermarket, machined and CNC'd heads. Looks like the new, beefier rocker from YellaTerra has gone from Bolt on part to "Bolt on part". Well, lets see how this bolt on crank scraper and windage tray goes then, shall we? There actually is more clearance than they specify for this thing, but seeing it all move as you check it is terrifying when you see it all so very very very very nearly hit things. But after all, this is what the item is designed to do after all and actually did bolt on perfectly and have enough clearance to everything and some very clear and direct instructions. So +1 to Improved Racing I suppose. As above with the windage tray on. Photo of breaker bar wonkiness for added lols. Next up: Oil pump/front cover/water pump/sump and then it's time to actually install the heads, pushrods, head bolts, valve cover gaskets and such is all there and ready to go. (except the oil pump bolts which were previously longer for more clearance with the previously perfectly installed double row timing chain). There's definitely a sense that someone other than us has been here before and done everything perfectly, or at least considered it and came up with working solutions. Perhaps the previous cam was 6deg advanced to avoid PTV issues with the milled stock heads? In any case when I attempt to sell this stuff the buyers are going to be very directly informed.
    • my catch can is pretty easy to empty but it overflows due to the blowby/crank case pressure etc. max I have drained is ~600ml even with a ~2.3L capacity. So it is not just about having to drain it out its the mess it makes down the firewall and under the car and rear passenger tyre from the overflow oil being blasted by screamer + air in general. Ending up on the ground cleaning the oil up and having oil on your arms when everyone else can chill and watch the other sessions gets old fast
