  Quote
Originally posted by KILLER-T
I think it was bad tuning that cost me my last engine it cracked a piston ringland and cost about 5.5k to rebuild and before anyone asks who did the tune i wont tell because im not 100%sure if it was the tuning
Adam,
Out of interest, what were the symptoms of your broken ringland? Was it a major failure that was obvious (bang, smoke, noises that shouldn't be there etc) or a gradual thing? I'm guessing there was audible detonation?
Cheers,
Matt
Guest KILLER-T
Hi whatsisname i had no warning didnt hear any pinging had it on a dyno for a tune up drove it home got up in the morning poped the hood and i noticed oil had been spraying out the BOV and boost solinoid .Took the car for a drive it still had heaps of power. So i took the car to PSI performance and he tested the comp ratios and thats when i was told the bad news that i needed a rebuild
Good to see all is well now mate (many $$$ later).
So on the pre "bad news" test drive did it make any nasty noises? Anything else (other than the oil out the BOV & solenoid)?
Thought it'd be a good idea to get a bit of this kinda' info on the forum, for future reference.
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
