Hey All,
Well it has come that time, sell the car or start pimping my ass!
The car in question is a R32 GTS4
Engine: RB20DET
Transmission: 5sp Manual, ATESSA 4wd
The car has all the mod cons; climate control a/c, electric mirrors, windows auto front spoiler and a working sunroof
The only modifications are:
a 3" Trust Cat back exhaust
Pod filter
Heavy duty clutch
Adjustable castor arms
The engine was replaced with a low k's import that used to be hooked up to an auto (I spun a big end) then I blew a turbo, and replaced it with a stock rb20 unit, the turbo still has visible balancing marks - currently running standard boost, the previous owner had a switchable boost controller installed, but I unhooked it - can be easily made to work. Now to the killer blow, the car was stolen one night, but fortunatly the only got 500m down the road before hitting a curb and breaking the castor rod (which I have replaced with adjustables) but has broken the pasenger side skirt. The filthy thieves then decided to try remove the wing with a screwdriver and damaged the paint on the boot and rear 1/4, I have repaired this and have it ready for a top coat (currently matt black) they then stole my sub and took the face off the sterio...
So baisicaly it needs a bit of paint, I spoke with a painter who said it would cost roughly $3-400, a new side skirt (or fix the old one) and a head unit or a new face (the speakers are 6.5" coaxials in custom door mounts behind the standard grills hooked up to a 2x100wrms amp, with all the cabling to support 500wrms in the boot) Otherwise, the car is mechanically great, I have been spending a lot of time carrying out every bit of maintenance I can find to do - cleaning afm, ic pipes, coilpacks, changed gearbox+diff oils etc... and I have a boot full of spare parts
So asking price is a negotiable $, to a good home, I will be sad to see it go.
Pm me or call 0400 996 522
Dave
Edited by Medium Dave
https://www.sau.com.au/forums/topic/146083-sold-r32-gts4-9000/
  • 1 month later...
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
