this type of coupling does not need grease or a dust boot. also most unit joints are run without a cover or grease. automotive CV joints need to be packed in grease, and need a boot to keep the grease in and the dust out.
ummmm, dont you guys know that cv's a packed full of grease etc etc?
i wanna see that fancy join full of grease with a rubber cover over it.
i really dont think they are use them in the real world uncovered and unlubed etc.
steve
Its a low friction joint it doesnt need to be packed with grease. Havent u ever looked at the cv joints connection a tractor to a slasher? most of them dont have rubber covers. Theres been alot in my local paper about thompson couplings as they are based in my town. I'm thinking about buying some shares, this company is about to go bigtime. When/If these become available for cars it will mean less drivetrain loss :P
Its a low friction joint it doesnt need to be packed with grease. Havent u ever looked at the cv joints connection a tractor to a slasher? most of them dont have rubber covers. Theres been alot in my local paper about thompson couplings as they are based in my town. I'm thinking about buying some shares, this company is about to go bigtime. When/If these become available for cars it will mean less drivetrain loss :(
i was thinking the same hey, i have alot of money left over from holiday.
I never realised that a Unijoint constantly speeds up and then down with each revolution at an angle. Thats a fairly major improvement on the exisisting technology, shares could skyrocket if it stands the test of time, from what I could see it relies on those pins inside the cage to transfer the energy but I couldnt make out what they drive, I assume it is a set of holes that the pins align in, the pins themselves would be the weak point but with new alloys progressing everyday its quite possible.
Looks like not a bad idea, looks bigger then the equivilent uni tho.
Unless it can provide something sort after, current uni's are cheap enough to replace quite often. I think we picked up a uni for $80 for a Inter S-Line truck the other day. They dont fail that often.
Cheers
Sumo
Cheers
Sumo
it was made to transfer power more efficently, with that i assume it will come with a price
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
    • Tomei or Nitto, don't use the OEM one or Cosmetic ☺️
    • After cleaning up a rusty cooling system in a 33 gtst that's been sitting for years it seems to have cleaned out the head gasket too haha. It seems the Tomei metal gasket works without machining surfaces? Or put oem? Also should put an oil restrictor while the head is off? Thanks
    • Thanks, I definitely saw the more expensive options from Crank and driveshaft shop. Thank you for the D-max option.  Still hopeful someone has an OEM out of the box option I found that the 300zx NA Left drive shaft is a good match for the Right on the R33. https://www.gsplatinamerica.com/product/ncv53040 Just need to find Left CV for the R33, I cannot find any <=22" axles.
