well u guys know i'd pwn u at the drags, so track & moutain would be closer (mainly caus u guys have HEAPS more experience than me, which i can quite honestly admit)
P.S i'm booked for the feb 2 & march 28 track days :)
  • Replies 107
but u got more experience now saying "i wish i had my car" after friday night :laugh:
Quick question for Squizz, after the mountain run, my suspension is a bit softer. Shocks still feel OK but the springs may have collapsed?? The new Whiteline adjustable swaybars are still doing their job but the springs feels really soft. They are only about 18 months old. Does this sound reasonable??
I would hazard a guess and say it's mental. If you have progressive rate springs they will "stiffen up" when driving spiritedly over terrain that is quite harsh, such as - Oh I don't know - a Mountain. Once you've come back to earth and settled down everything seems lame.
I doubt your springs would have collapsed, if they did it would feel harsher, not softer.
i think i need to dial in a bit most castor and camber for the mountains, the current setup runs good for track but feels a little wrong for touge.
I will be in for the next one, i don't really get down to the gold coast runs much.
It would seem Squizz is still smashing people up top the mountain. Told you fags no-one could beat this crazy mofo :/ You can do all you like to your cars to get them to handle better, but what's required is YOU to handle YOUR CAR better! :laugh:
Sounds like a grand evening! :)
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
