Get the car tonight, counting down the time. lol
Anyway he has the car set on 0.9 boost how much should or can u run day to day? how much is to much? can it go any higher? or wot?
thanks
That will be .9 Bar which is about 12-13psi! and on a stock turbo you could prob run a little more but, would prob leave it at that!
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729069
a mate of mine told me 1.0 bar is about right should i change it or jus leave it? how do u work out how much psi it is? is there a formula or something?
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729092
bar x 14.503861 = psi
so 1 bar would be 14.503861 psi
if you're running a stock turbo, i'd be careful about running 14.5 psi.
i'd be leaning more towards 12psi as a max, or even 10psi as a safer level.
depends on your setup of course.
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729103
Its been tuned at that boost level so leave it. :(
It might be a good idea to throw it on the dyno for a quick power run 'just' to make sure everything is in good working order.
AFR's are nice and not pinging.
Blackwood auto & dyno used to do power runs for $30, cheapest around by far. Other than that take it back to shaun/Boostworx as he knows the car I would presume. :(
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729142
ok cool. i have heard everyone one here speak of boostworx! must be a good place and shaun seems to be well liked. will defiantly be taking the car back there for any work
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729159
rules when owning a turbo car
1 DO NOT LISTEN TO WHAT "MATES" SAY ABOUT DOING ANYTHING
2 ASK SHAUN IF IN DOUBT
3 IF ANYONE ASKS HOW MUCH "BOOST YER RUNNIN" SAY 32PSI NO MATTER WHAT
haha ok ill keep that in mind! number 2 is good advice thou, is he happy to help out over the phone? or not
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729214
addition to that
4. IF MATES SAY "SHAUN SAID...." DOUBLE CHECK TO TELL IF THEY JUST SAYING THAT TO ENFORCE THEIR POINT
lol
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2730045
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
