Get the car tonight, counting down the time. lol
Anyway he has the car set on 0.9 boost how much should or can u run day to day? how much is to much? can it go any higher? or wot?
thanks
That will be .9 Bar which is about 12-13psi! and on a stock turbo you could prob run a little more but, would prob leave it at that!
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729069
a mate of mine told me 1.0 bar is about right should i change it or jus leave it? how do u work out how much psi it is? is there a formula or something?
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729092
bar x 14.503861 = psi
so 1 bar would be 14.503861 psi
if you're running a stock turbo, i'd be careful about running 14.5 psi.
i'd be leaning more towards 12psi as a max, or even 10psi as a safer level.
depends on your setup of course.
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729103
Its been tuned at that boost level so leave it. :(
It might be a good idea to throw it on the dyno for a quick power run 'just' to make sure everything is in good working order.
AFR's are nice and not pinging.
Blackwood auto & dyno used to do power runs for $30, cheapest around by far. Other than that take it back to shaun/Boostworx as he knows the car I would presume. :(
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729142
ok cool. i have heard everyone one here speak of boostworx! must be a good place and shaun seems to be well liked. will defiantly be taking the car back there for any work
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729159
rules when owning a turbo car
1 DO NOT LISTEN TO WHAT "MATES" SAY ABOUT DOING ANYTHING
2 ASK SHAUN IF IN DOUBT
3 IF ANYONE ASKS HOW MUCH "BOOST YER RUNNIN" SAY 32PSI NO MATTER WHAT
haha ok ill keep that in mind! number 2 is good advice thou, is he happy to help out over the phone? or not
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2729214
addition to that
4. IF MATES SAY "SHAUN SAID...." DOUBLE CHECK TO TELL IF THEY JUST SAYING THAT TO ENFORCE THEIR POINT
lol
https://www.sau.com.au/forums/topic/146166-boost-how-much/#findComment-2730045
