Hey,
I just need to know what this hose is called (circled in red) it was brittle and needs to be replaced. Also, if anyone knows where I can buy it from that'd be great too.
Thanks guys!
Note: Image was taken from Ebay
https://www.sau.com.au/forums/topic/146172-what-is-this-hose-called/
Hey,
Thanks guys!
If your looking at getting a oil catch can then it would replace that hose. Can pick up catch cans for 80 bucks these days.
BTW Think it's called the oil breather/return hose
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
