Guest adman
the best thing to do in this case is find a workshop that has a "Snap-on" scanner, 'caus then you can actually reset the factory idle and fuel trim settings to remove the problem(aswell as a heap of other cool adjustments and actuator tests) and also see if the E.C.U has any stored fault codes which will point you in the right direction!!!
I highly recomend this!! Cheers, Adman
