I've got a R32 GTR and it makes a whining noise under acceleration above 60kph or so, when I release the loud peddle the noise goes away. The boost is okay and the car goes just fine besides this stupid whining noise (note: girl friend not in car :))
Thought it might be thrust bearing but when its idling its not noisy (rattles a bit coz I got a twin plate clutch).
any1 got any ideas about this one.
cheers
https://www.sau.com.au/forums/topic/14624-whining-noise-under-acceleration/
  • 5 weeks later...
the noise is probably coming from your gearbox or diff, (possibly)
its a common import problem, have you changed the oils?
persuming that this is the problem , my car does the same, probably alot of other ppl's too just they dont realise.
as for a soloution, i got no idea. but there might be some comfort in knowing your not alone. :P
Could be even something like the alternator, and all the belts around that area or the bolts. More revs its spinning faster, could make sense - but then again it could be any one of the things those guys suggested..prolly gearbox most likely.
Don't know if an R30 can even be comparable to this, but neway i have a whining noise coming from the transmission which is pretty screwed at the moment, so my guess is that it would either be your transmission or diff:D (But dont be like 1 of my mates who put banana skins in the diff to make it seem smooth *sigh*)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
