I've got a R32 GTR and it makes a whining noise under acceleration above 60kph or so, when I release the loud peddle the noise goes away. The boost is okay and the car goes just fine besides this stupid whining noise (note: girl friend not in car :))
Thought it might be thrust bearing but when its idling its not noisy (rattles a bit coz I got a twin plate clutch).
any1 got any ideas about this one.
cheers
https://www.sau.com.au/forums/topic/14624-whining-noise-under-acceleration/
  • 5 weeks later...
the noise is probably coming from your gearbox or diff, (possibly)
its a common import problem, have you changed the oils?
persuming that this is the problem , my car does the same, probably alot of other ppl's too just they dont realise.
as for a soloution, i got no idea. but there might be some comfort in knowing your not alone. :P
Could be even something like the alternator, and all the belts around that area or the bolts. More revs its spinning faster, could make sense - but then again it could be any one of the things those guys suggested..prolly gearbox most likely.
Don't know if an R30 can even be comparable to this, but neway i have a whining noise coming from the transmission which is pretty screwed at the moment, so my guess is that it would either be your transmission or diff:D (But dont be like 1 of my mates who put banana skins in the diff to make it seem smooth *sigh*)
    • My son has an R34 gt auto. I'm looking at methods on how to tune it with the view to be able to further tune it down the track when he is off his P,a and can go turbo. The issue is the 98 gt auto has a seperate TCM and is not compatible with swapping out a gtt auto nistuned pcm ( from what I have read so far ) Please if anyone has info on what to do here I would much appreciate. Realise that some options include manual swap, manualised valve body. Just hoping there is a more direct running option I haven't been able to find. Thanks in advance.
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
