Hey guys, I've recently been experiencing my Hicas light on the dash flash on and off on occasion, like many others have experienced. My steering is now crazy stiff as if there's no power assist, but the fluid is full.
This happened over the period of about a week, starting with just the light, and progressing to the tight steering.
I've searched Hicas and a lot of you have been experienced different problems and have suggested the hicas lock bar. Does this bar fix all problems relating to the HICAS? Anyone had this particular problem, replaced the bar and fixed it?
Could the HICAS light suggest other problems, such as the vehicle speed sensor? I'm thinking this could be the culprit, but without the means to check the OBD codes, I can't be sure. Is there any other way?
Cheers.
Richo
PS. Sorry, I just realised I may have posted this in the wrong section.
Edited by siiick
https://www.sau.com.au/forums/topic/146277-hicas-and-steering/
  • Replies 50
When this happened on mine I found it was an electrical problem, I fixed it by unclipping all the plugs and spraying them with Lanox, I couldnt figure out which one it was but it fixed it, when I say all the plugs I mean every one from front to back.
yep follow his directions, mine was electrical related also, note if u leave ur battery terminals off for a period of time, it will come good, after system reset. It was suggested to me, this is hicas diagnostic mode. there may have been some dirty on the connections, as we pulled all the plugs off, blew them out, and havnt had the issue return.
cheers,
  • 10 months later...
Update ** the problem is back for me.. 'siick' did you end up fixing the problem.??
Something else I noticed this time around is..
When the hicas light comes on, and the steering becomes stiff (ie. no power steering), the ACC control doesnt work. I notice No blip when moving the steering. I have checked all fuses this time, and all is ok. I will take off all plugs again, and clean up, see how it goes.
It is said the heavy steering is a "low assistance mode"
which happens when there's a HICAS ECU error code.
I found a HICAS diagnostic test that you can do manually -
http://www.overflow.250x.com/diagnostics.htm
Another way is to go to your local Nissan dealer
and check via Consult (diagnostic computer).
Consult should be able to access the HICAS
ECU error codes.
Also other causes of HICAS problems can be weak
voltage because of a faulty alternator or low
fluid level in the powersteering resouvoir (R32).
Sometimes the HICAS ECU (like a faulty AFM) can have
bad solders. It's not worth fixing and I recommend a
second hand replacement HICAS ECU.
But be aware that GTS, GTS-T, GTR HICAS ECU's are
supposedly not the same (part numbers are different).
Make sure you have the correct replacement HICAS
ECU.
Edited by SKYPER
thank you that is some really good info there.
"The HICAS light in the instrument cluster will be flashing quickly (for normal) or will flash a code indicating any problems. Long flash = first digit, short flash = second digit. Diagnostics will return to normal after five minutes, or any speed over 10k/ph, or ingnition is turned off. "
But will this work with a non standard ecu.. for instance a PowerFC
Have you been able to get into this Diagnostic mode yourself 'Jdfng' ? I have not , even back with my stock ecu, and now with the PFC. I have tried Extensively tonight, to get it into diagnostic mode, following the instructions on that website exactly. And also tried a few variations of the instructions aswell.
as prior to this last time I had issues with the stock ECU, I did try a few times, with very similar instructions to that website, that didnt work either.
In the end I gave up, the problem just kept returning no matter what I did, the plug spraying always cured it but only in the sort term, I looked at the options available and settled for the Tomei hicas lock kit, mainly because it is fairly simple with the hicas unit staying there but locked with spacers and a elec unit to fool the main ecu into thinking all is good with it, the other option is a lock bar which replaces the hicas unit.
I never got the diag to work either.
About the link, you're welcome. :)
That manual HICAS diagnostic mode does work on a R32
and it worked first time. Only problem was getting it into
full diagnostic mode as HICAS ECU threw a tantrim.
Basically the rear wheels felt like they were turning side to side
and light flashed on the dash (R32 had a faulty ECU at that time).
Driving backwards or forwards at less than 10kmh didn't do anything.
I think you might need to turn the steering wheel between
turning on ignition and the revs rising on the dash. I guess
probably by the time revs have risen and settled at idle,
a couple of seconds has passed.
As far as I know the only difference is R33 has a separate
HICAS system in the boot (not feed by powersteering
resouvoir in engine bay).
The R33 powersteering resouvoir is sometimes used
when eliminating HICAS on R32.
Edited by SKYPER
This is Correct. which makes that tutorial quite useless for anything other than R32.
The issue has seemed to have dissapeared this morning :)
Theres gotta be someone out there, who knows how do diagnose Hicas R33 onwards. Im not keen on using a lock bar. As I plan on using the Hicas to its full potential, And solving this issue! :rofl:
yeah mate i have had in diagnostic mode a few times... Having said that, the last time I tried it, it flashed up the codes but didn't do it's wheel moving thing...... But it still flashed up the error codes.....
i might try re-setting the ECU and go from there... I tried it on my mates R33 the other day and it flashed the error codes... still no bum wiggling though...... not really sure why........
semd me your number by PM mate and I'll give you a call and talk you through it if you like :rofl:
would come over and show you but it's a bit too far to come :)
R32 had a faulty HICAS ECU at that time, so I guess that's why the rearend
wiggled.
Replaced ECU, no more heavy problems.
Do you guys have an aftermarket boss kit for aftermarket steering
wheel (could be interfering with HICAS steering angle sensor that's
located behind steering wheel)????
Edited by SKYPER
Still, get the steering angle sensor checked out.
I guess another way would be to find the same type of car and swap over HICAS ECU's.
Then see if the problem appears on the other car. I gather it would eliminate HICAS ECU
as the problem.
Also check the HICAS ECU plug as sometimes the plastic plugs can get bent (had this
problem with engine ECU plug).
Edited by SKYPER
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
