  • Replies 73
Posted Images
wouldnt it be really obvious if it was rear wiper. i mean, if you press it, your rear wiper will start, and then we wouldnt be having this discussion :D
so i'm guessing you guys have the rear wiper control on the left stalk with the regular wiper? like r33?
https://www.sau.com.au/forums/topic/146296-strange-button/#findComment-2733378
Attached is a picture with a button that I do not understand. What does it do?
thanks
That is a mirror heater switch ( it heats up the 2 exterior mirrors) and its located on the right side of the steering wheel. This is not a guess its fact , the reason i say this is because you are going to switch it on and probably nothing will happen. I hear you say why? Because the compliance shop have changed the the glass in the mirrors ( because they dont comply, no "E" mark on them ) , the heaters are on the actual glass!!!
If you take one of the mirrors off you will see the lug there going nowhere.
https://www.sau.com.au/forums/topic/146296-strange-button/#findComment-2733898
There are also heating panels on the front and rear windscreen where the windscreen wipers sit.
It's designed so that you can get in your car in a snowy environment and flick the switch and your wipers wont stick to the window.
Chances are you have a red and white light in your rear bar like mine?
You have a mountain car like me!!!
https://www.sau.com.au/forums/topic/146296-strange-button/#findComment-2734997
wouldnt it be really obvious if it was rear wiper. i mean, if you press it, your rear wiper will start, and then we wouldnt be having this discussion :laugh:
I am thinking...thinking...thinking.....Wiper/blade eject switch...auto relacement button.
But might be to obvious,,,so I will go rear wiper switch.
But don't take my answer as being correct...could be anything...lol :happy:
https://www.sau.com.au/forums/topic/146296-strange-button/#findComment-2736347
But don't take my answer as being correct...could be anything...lol :(
I am thinking...thinking...thinking....your a very foolish person who talks alot of rubbish :)
Im with wrxhoon, sounds pretty clued up to me :)
https://www.sau.com.au/forums/topic/146296-strange-button/#findComment-2736838
Bass Junky is correct, it is actually for the Front windscreen demisters. Not all R34s come with it as it was an option.
If your car has the original windscreen, you will see the demistera near the wiper blades
ahh sweet i think we're on to something now. bass junky, indeed, my car has one white reverse light and one rear fog light, and a person who could decypher japanese tells me my rego sticker (still have the original jap one lol) is from hokkaido (the northern island of japan).
hmm mystery solved? will have a look at the windscreen in the morning - don't know if it's the original one....
https://www.sau.com.au/forums/topic/146296-strange-button/#findComment-2737117
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
