Ok all so please read the following post to get up to date.
http://www.skylinesaustralia.com/forums/in...p;#entry2732110
So basicaly this is the problem.
I installed a new GIZZMO boost controller, and it apears that the controller is stuffed so getting a new one, but this morning it decided to work for a little bit.
So at a settign of 10% duty, i managed 10.6 psi, but the strange thing is that the boost is only 7psi below 4500rpm, then once the cam has swithed over, it goes up to 10.6psi. I can set the gain then, but i manage to get funny overshoots, and if i back it off, it is very slow to build boost.
The problem i am having, is that it appears there may be some issues with my wastegate. below 4500rpm the boost is steady at 7psi, and above it shoots up to 10psi, eaven with no boost controll, ie. direct coupled wastgate to IC piping. I pulled the cover off and checked the wastgate, and by presurising it with a pump, i could see it move a good 3cm, the wastage arm that is, I presume that is enough. I took the arm off to ensure that it has not moved or something, and it appears to be ok. The wastgate shuts nice and firm, but the boost overshoot has me warried. It makes me think that my wastgate is too small or something.
Now the car is a stock r33, with a FMIC, HPS pod, Flyen 3" belmouth dump, no cat and 3" exhaust. SAFC II tuned pump, etc etc and stock turbo.
I was also wandering if it can be the dump pipe or the cat, causing turbulance or something of that nature? Can it be my turbo dying as well?
ANYONE help. Can you also get a softer spring for the turbo to allow for better boost controll?
For all those with a GIZZMO IBC or simmilar problems, can you shed some light so that i know what to look out for.
FORGOT TO MENTION, my coils are stuffed and i need to run a gap of .6mm to be ok, can this cause problems too?
PLEASE
Edited by WogsRus
i went to see him, the issue is that the wastage should not be silyl as is, plus i still have the new coils to put in, the CAI to make up, and a few other befero i go in for a retune.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
