What if u just bought the whole instrument cluster? Would that re-calibrate it......i was thinking this, before when tossing up between the 320 vs 180 white faced dials. got the 180 cause seriously how often do u go above that. and on the drag strip u get told how fast u were going anyway! Plus personally i think they look better with just the middle lighting up and being able to jump between blue and green just by pressing a button.
If you purchase the nismo dash cluster you can just plug it in and its all calibrated. They also look fkn sweat when ya turn the head lights on :rant:
  • 3 weeks later...
to the guys that have installed the el dials, what did you use to stick them down with? i tried super gluing them down but the needles get stuck on different parts of the gauges because i cant get them to sit dead flat?
cheers guys
