Hello, i've got a GFB aftermarket bov on my r33 made specifically to bolt onto a r33. however i want to get that flutter noise more, do i just remove the bov somehow completely? i'd rather have the flutter more than the "pttshh" lol.
What do i have to seal off/relocate, any help would be grateful!
Cheers!
Edited by NeesaanGTS
https://www.sau.com.au/forums/topic/146343-flutter-noise-how-do-i-get-it/
If you remove just the Vac line you will get the noise but the car will run like crap.
Dont do it.
no it wont! because he has an aftermarket bov. This wont work with a stock bov thou
one more thing!
NOT GOING TO ANSWER THE DUDE QUESTION THEN DONT POST - FFS im sick people posting pointless crap
re-mount you AFM onto your intercooler intake pipe and then run a straight pipe straight off the turbo... size and length od intercooler pipng will determine the noise you get
Also the shape of the pipe that comes off your tubo will give you different sounds
Edited by ctjet
thanks to those who gave helpful replies, and no i aint getting a vl haha. Is there a way i can get rid of the BOV and not have the car running rough?
i haven't been able to find a stock one yet to replace it, i'd just rather have no pttshhh noise you can easily hear, the flutter is better :wave:
http://www.skylinesaustralia.com/forums/in...;hl=bov+flutter
Listen to this guy, he so far is the only 1 who is right. Having a larger turbo also increases the noise
exactly right, done it to my r33 and sound exactly like a vl, dont bother pulling off vaccum hose or blocking off bov, do exactlty like this dood described
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
