Nissan A31 Cefiro
ENGINE
- RB20DET
- 5 Speed Manual
- New timing belt
- New alternator/Water pump/power steering belts
- New Platnum Spark Plugs
- Front mounted Intercooler
- Blitz Style Blow off valve
- Sports Filter
- Full turbo-back custom built 3inch exhaust with Hi-flow cat and magnaflow rear muffler
- R33 Series 2 Turbo
- Braided Turbo lines
EXTERIOR
- New Gold paint with rainbow flakes
- Fibreglass wide front guards with custom vent
- Custom rolled and pumped rear guards
- Completely debadged body
- Rear height adjustable springs
- Custom front grill
- Tinted lights all round
- Tinted Windows
- twin 3inch chrome rolled exhaust tips
- New 18inch Alloys
- New Kumho tyres all rounds (235 @ front, 245 @ rear)
- Full URAS bodykit
- Adjustable rear camber arms
- Removable decals
INTERIOR
- Full electrics
- Turbo timer
- Original Cefiro Floor mats
- Short Shifter
- 2-way pager alarm
- Factory Black and grey Trim
- Sports steering wheel
STEREO
- JVC CD\MP3 Player
- Audioline 800Watt 4 channel amp
- Kicker EX 12inch Subwoofer in orginal Kicker box
- Pioneer 6.5inch rear speakers
- JVC 6.5inch front component Split speakers
- Full Audioline amp wiring kit
Reg and RWC included. Price negotible.
This vehicle grabs alot of attention. Firstly for being so unique and secondly for how it looks and goes. This car is a current promotional car for AUTO INDULGENCE and EXOTIC PANELS. Car has always run stock boost or under. All work done recently and was bought stock standard.
Extremely regretful sale due to needing a not so nice car to drive into the city for work or to leave at the station. Will not disappoint and do not miss out.
$16500.00
Cefiro Ad on Carsales.com.au
Edited by Mr Drifter
https://www.sau.com.au/forums/topic/146353-nissan-a31-cefiro/
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
