I know this topic has been discussed at great length..but I though that I would let you all know that I just got an email form the guy that sells these units informing me that it is now available and proven to work on stageas!....I have contacted him and asked him to supply more details.I am sure lots of us will want one if he can assure us that they work safely. Sounds to good to be true and I know others have said its not possible..I will post again when I get the details.
He has them on speacial at $199. plus postage...stay tuned!
Scott.
https://www.sau.com.au/forums/topic/146359-rwd-at-the-flick-of-a-switch/
Here is the email from the seller of the TSC units:
Hi Scott, You are correct in that you cannot run RWD on the Stagea. The only vehicles that can are R32 GTR & GTS4's. However, the main functionality of the Extreme TSC, which is torque split control (controlled by the dial from 1-10), does work perfectly on the Stagea. You get the same functionailty as you would if you had an R33 or R34 GTR fitted with the TSC.
What do we think?....worth the bucks?..would be good to hear from anyone that has one already one in a R32.
Scott.
there was a good article about this in one of the auto mags a while ago see http://autospeed.drive.com.au/cms/A_0060/article.html
I have no idea why the electronics for this should cost $199 - I suspect $49 would be more appropriate...
Edit: and that's $10 for the parts, $39 for profit.. See the diagram near the end of the article ie two op amps and a few resisters and a pot..
Ian
Edited by ian
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
