I know this topic has been discussed at great length..but I though that I would let you all know that I just got an email form the guy that sells these units informing me that it is now available and proven to work on stageas!....I have contacted him and asked him to supply more details.I am sure lots of us will want one if he can assure us that they work safely. Sounds to good to be true and I know others have said its not possible..I will post again when I get the details.
He has them on speacial at $199. plus postage...stay tuned!
Scott.
https://www.sau.com.au/forums/topic/146359-rwd-at-the-flick-of-a-switch/
Here is the email from the seller of the TSC units:
Hi Scott, You are correct in that you cannot run RWD on the Stagea. The only vehicles that can are R32 GTR & GTS4's. However, the main functionality of the Extreme TSC, which is torque split control (controlled by the dial from 1-10), does work perfectly on the Stagea. You get the same functionailty as you would if you had an R33 or R34 GTR fitted with the TSC.
What do we think?....worth the bucks?..would be good to hear from anyone that has one already one in a R32.
Scott.
there was a good article about this in one of the auto mags a while ago see http://autospeed.drive.com.au/cms/A_0060/article.html
I have no idea why the electronics for this should cost $199 - I suspect $49 would be more appropriate...
Edit: and that's $10 for the parts, $39 for profit.. See the diagram near the end of the article ie two op amps and a few resisters and a pot..
Ian
Edited by ian
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
