One Of Adelaide's Toughest Street S13s........over $30k Spent.....
For sale: 1990 S13 Silvia
Asking Price: $16,000 firm
Kilometre's: 70,000 (exact km when I next see car)
Manual or Automatic transmission: Manual 5-speed
Engine Type: SR20DET 2.0 RED TOP
Complianced: Yes, this car is not a 15y/o import. It was fully complied.
Road Worth Certificate: N/A in South Australia
Registration: Yes, car has some registration still remaining on it.
Modifications:
This car is so extensively modified that some modifications may have been forgotten...
Body
Custom yellow paint with black roof. This is a one of a kind colour that I mixed personally. It is as bright as yellow can get.
Genuine Origin Stylish Front Bumper
Genuine Origin Stylish Side Skirts
Genuine Origin Stylish Rear Bar
20mm wider vented front guards
Custom FULL METAL 40mm wide body rear ($1700rrp)
15mm bonnet spacers fitted for cooling
Shaved boot with no wing
All badges and side moulds removed
All bodywork has been completed by none other than M&C Doyle Auto Refinishers, so it is premium quality.
Brakes
Full GT-R brake upgrade with 5-stud conversion
R32 GT-R discs and calipers all round
R32 GT-R drum handbrake setup (with custom brackets to mount lines etc)
Suspension
Adjustable rose jointed castor rods
Castor rod brace (supplied but not fitted)
Adjustable rose jointed rear camber arms
Adjustable rose jointed traction rods
Adjustable rose jointed rear toe arms
Metal cradle bushes
Solid gearbox mount (supplied but not fitted)
Solid steering shaft spacer
Top of the line fully adjustable Silk Road/Section RMA8 coilovers (adjustable king pin, camber, height, damper, body)
8 kg front springs
6 kg rear springs
27mm solid Whiteline S13 front swaybar
24mm solid Whiteline R32 GT-R rear swarbar
15mm hubcentric bolt on spacers on front
Engine
1994 SR20DET redtop
3 inch mandrel bent front/dump pipe
3 inch mandrel bent exhaust system
JunBL Racing Spiral dual outlet muffler with trumpet tips (Exhaust Technology special)
Genuine Hybrid intercooler
Genuine Hybrid intercooler piping kit
Bosch 040 fuel pump
Cold air intake with pod filter
Custom oil catch can (lies across fan shroud, but not currently hooked up)
Car has made 165rwkW on 1 bar boost. Easily spins 4th gear during drift.
Driveline
Extreme 5-puck button clutch
Cusco 1.5 way mechanical LSD
Interior
Car is fully stripped inside. All that remains are door trims and dash.
Car is registered as a two seater allowing legal roll cage to be fitted, and bucket seats.
Sparco Sprint full bucket seats (Driver AND passenger)
Sparco deep dish rally wheel
Sparco gearknob
4 point race harness (supplied but not fitted)
Spin turn handbrake button
Rolling Stock:
The car will be sold with a set of 17x9.5 +15 Koya Driftek’s fitted.
For an additional $1000 the Drifteks will be replaced by the Work Emotion CR-Kai’s as seen in the photos (17x9 +17 front, 18x9.5 +12 rear).
Other Notes:
This car is exceptionally well set up. It has been aligned many times by Scotty at AVS Suspension to find the perfect setup. It feels extremely stable and predictable at all speeds. Aussie and CRAB 86 can vouch for this. The car is more than competitive at any level with the right driver, be it Super Drift OR Drift Australia.
It has covered about 3000km (if that) in my hands since I purchased it over 3 years ago. The car has had 3 oil changes in that time using only premium products. The car is currently running Elf motor oil, and Martini Racing gearbox and diff oil. It has always been maintained to the highest standard. It will be sad to see her go.
Pictures:
Contact detail's: Benny Mack – 0410 278 984 or PM me on here.....
road registration?
sorry if i didnt see it in the essay description... :P
as in... did your N/A mean "is not available"... or "not applicable" for RWC?
Edited by SAZilla
We don't have roadworthy certificates in South Australia. The car has full SA rego, which is all you need to take it interstate and transfer it etc. This car can be driven on the street which is rare of something this modified....i spent a lot of time clearing a defect I had on it so people could enjoy it more.
Thanks for the support guys. The car is still for sale if anyone is looking for a pre built drift car that has had hardly any drift done in it (G1 and 2 practice days). Everything is still fresh and car drives beautifully.
Yeah motor itself is internally standard with most standard bolt on bits etc.
Was never necessary to make more power than it does. That is for the next owner to work on......$2k and it'd make 220rwkW reliably....i just can't justify doing it to sell the car, hence the cheap price.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
