hey fellas
recently i have heard this weird sound between 1600 - 1800 rpm. It is a quick tapping sound and kinda sounds like a cricket or something. I took it back to the dealer today and he says that its probably a "gudging bolt". Im not quite sure if thats how its spelt, but its the bolt that holds the piston to the conrod. I guess its kinda hard for you guys to make a judgement without hearing the sound but any help would be greatly appreciated.
By the way its an RB25DE hence non turbo
https://www.sau.com.au/forums/topic/146451-i-think-my-rb25-is-dead/
gudeon pin i think he meant to say...Yes it does hold the conrod to the piston, but i doubt he could guess that straight from hearing it and be 100% correct. Best to get her comp checked and leakdown test etc, then if no problem seems to come about, then outsource someone pop her open and check her out. If theres a problem, may pay to look into a RB25DET replacement or rebuilding her for a turbo. Up to you.
R32 Abuser, what do you mean by comp tested and leakdown tested? And when you say etc is there any other test in specific that you are refferring to? Im willing to try everything to fix this. THis is last f**king thing i need to go wrong with my car. Are all skylines unreliable or is mine just a lemon.
it gets marginally quicker as the revs go up. Oh and yes it was the Gudeon pin which i was talking about.
Wheres the best place/cheapest to have this looked at. Since im at bulimba i dont wonna drive the car too far considering the state that its in. Anyone know of anywhere in the bulimba/hawthorn/balmoral/ surrounding areas. Im currently working with tuff toys (who i orginally purchased the car from) but they dont really wonna know about it until the engine breaks :(
YES. i changed the oil and there was the slightest bit of grit in some parts of the oil. Like it was finer than a grain of sand but i could still feel it. Whats the next step? Bearing trouble means i need a new engine doesnt it?
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
