OK not much left, open to offer's. Just want this stuff gone its in the way...
Rear Leather type Seat, light and dark grey no rips or tears $350pick up
Door trims have matching leather inserts if you buy the rear seat extra $50 and exchange for original trims.
Carpet, grey, no stains $50
Interior Trims : offer's?
ABS module $100
Front passenger seat belt $100
Rear seatbelts: $50each
Interior Lights $15 each
Hoodlining $30
Hicas Pump on diff $50
Pwr steer resevoir $20
Master cylinder $50
Pic's:
Rear Seat:
http://i105.photobucket.com/albums/m238/Ms...80/DSCF3160.jpg
http://i105.photobucket.com/albums/m238/Ms...80/DSCF3161.jpg
http://i105.photobucket.com/albums/m238/Ms...80/DSCF3162.jpg
Door Trims:
http://i105.photobucket.com/albums/m238/Ms...80/Image294.jpg
http://i105.photobucket.com/albums/m238/Ms...80/Image293.jpg
Centre console:
http://i105.photobucket.com/albums/m238/Ms...80/Image291.jpg
Im in Bunbury South of perth WA, will post at buyers expense
call or sms on 0419943997
Edited by msports180
https://www.sau.com.au/forums/topic/146462-various-r34-4-door-parts/
  • 3 weeks later...
will try to get some soon.
it just the guts of the gauge's, not the bit they sit in in the dash. Handy if someone has a gauge not working etc.
hey mate I know it's a low offer, but will you do the rear seat and all 4 door trims for $300? I can post back my front door trims if you need replacements. Things is I already have the material to cover the rear seats and door trims but am too lazy to fit it. Where are you and any idea on freight cost to Northgate, SA, 5085? Cheers, Andrew
Not that low sorry
i would think that frieght on that wud be at least $200+, as a body kit from SA to WA was $350 wud be roughly the same size.
  • 3 weeks later...
  • 4 weeks later...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
