Cusco Zero 2 R Coilovers - To suit R33 GTR, have been told will also fit R34 GT-T and R34 GTR. They are height Adjustable, as well as having base height adjustment and dampner adjustable. Currently have 9kg\mm front and 7kg\mm rear springs. After $1350 Delivered. - Will get pics up tonight.
Trust Solid Piping Kit - To suit R33 GTR only!!, only recently bought this from Beer Baron a week ago here -> http://www.skylinesaustralia.com/forums/in...=143480&hl=, is in good condition except is has miss matched silcon hose with one silcon joiner missing. I'm after what i paid so $400 delivered
HKS Super Hybrid Panel Filter - Suits R33 GTR stock air box, may suit GTS-t also? Approx 500km old Perfect Condition, I'm after $60 delivered.
HKS - QLD Prestige Number Plates - Black Writing on white background $3500.
PM me or reply here if your interested.
Edited by ookami
selling because i need to get out of debt and the car wasn't selling with all these parts on it so selling seperate and lowering the price of the car.
Are you positive the trust piping kit wont fit a 32gtr? .. i thought 32 and 33 should fit the same. If they fit a 32 ill take them 4 no dramas
If i had a Silver GTR i'd buy those rims, they look the goods on the silver GTR. Hell if i was looking for a GTR i'd buy yours with all the bits.
You after anything in trade for the rims? I really want them but cant stretch to that amount atm. I will be ditching a set of R34 GTR rims if you're keen.
Christian
Wheels, wheel nuts and camber arms are 100% sold and paid for. Thread updated.
Edited by ookami
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
