Hello.
Recently ive finished installing my new stereo in my 33:
Alpine:
9857 H/U
4 x Type X Splits
MRV-F345 4ch amp
Now i have wired everything up all nice and neatly and didnt take any shortcuts, soldered things where needed and etc, and i have tuned my amp according to my listening preferances.
The problem im having is everything rattling! my parcel tray and my front doors. I have the fronts mounted factory and no sound deadening atm. I was just wondering which was the better alternative; take it to someone and get them to completly seal and sound deaden my doors, or take it to someone and get custom speaker pods built to suite the speakers.
Now the back speakers, would i be better off sound deadening all the metal part of where the parcel tray sits and replacing that crappy piece of wood/cardboard with some sturdy MDF? or what could be a better alternative.
Next year once i have a bit more cash ill be getting a new super plush carpet mould with full sound deadening on it so that will reduce some drivetrain/ground noise.
I have spent alot of money on the system and i want top quality sound from it and im not sure what to do about this situation so any help would be great.
Another thing regarding subwoofers and my boot, Next year ill be after maybe 2 type x subwoofers, and ill be sound deadening the entire boot.
1. Do i sound deaden the boot lid as well?
2. With the r33's im sure everyone knows that crappy little waste of space where the battery sits, does the piece of metal between the cabin and the boot hinder bass in the cabin, and what do people do about it?
thankyou.
Edited by OBNXSH
1) I think that is recommended. Deaded as many large panels as you can. It gets expensive though.
I have just done the metal parcel tray, and it doesn't rattle anymore. I have made my own parcel tray also, out of thicker MDF.. that's definately the way to go. The stocker is cardboard-thin!
2) As far as I know, noone has touched that before. If you want to experiment, I guess you could remove the rear seat, then use a hole-saw to drill two chunky holes, then ram a bass-reflex port that protrudes in to the battery/boot area? I guess the seats are going to muffle anything that's already there anyway.
I have put a guide somewhere on helping with the doors. The door trim has metal tabs that hang on the door-sill... metal on metal shakes like crazy. The furry side of velcro on the door-trim tabs was a simple solution there, but you COULD soundproof the entire door. I'm quite happy with what i've done, and it's noise-free now. (apart from some road-noise that Dynamat panels could reduce)
I found that my rear bar doesn't vibrate, but the boot lining at the end of the boot (the lining that covers the brakelights and bootlock) is vibrating quite badly against the metal of the car.
From the outside, it sounds like the rear bar.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
