The boot on my R33 is jammed shut. The boot release lever at the side of the driver's seat doesn't have the normal pressure when i pull it, and although i hear a faint sound when i press the boot release button on my alarm system, the boot doesn't unlock.
I've tried pulling up the boot with the lever up but it doesn't work.. i suspect it's the locking mechanism or boot which is jammed or something.. and it probably happened a few days ago when my friend slammed the boot shut =_=
It's kinda hard to describe, but the left hand side of the boot is slightly open, but the right hand side of the boot is closed (I an tell by looking at the gap between the body and the boot), so the boot is actually closed at a slight angle.
The lock on the boot is broken too, so I can't use the key to open it.
Is there any way which I can get it to open again? I've thought of removing the back seats to access the lock from the inside, but how do I do that, and will it help?
https://www.sau.com.au/forums/topic/146509-r33-boot-stuck-shut/
Nah... unless you can reach through the speaker holes, you can't get through to the boot like that.
It shouldn't half open unless something is jamming the arms that the boot swivels on. There is only one latch that holds it shut.
As for the loose handle, it's possible that the wire has come loose... If you have a look under the carpet, you should see how to adjust it. (or pull it with a pair of pliers until the boot opens)
Carpet... carefully pry one side of the skyline door-sill up, then move your hands across, and unclip the next etc etc. From there, you can unhook the side of the carpet and have a better look at the mechanism.
I've heard of people drilling the lock out and replacing it when they were stuffed. I guess you really don't want to do that, so check the cable tension first. =-]
Worst comes to worst, if you need to get into the boot to fix the lock, you can remove the back seat, then remoev the boot inspection panel. There is a lot of stuff in the way, but that can be unbolted from the cabin and moved.
you might not be able to crawl through the hole, but a small kid can.
The hole is sharp though.
Sounds like something is jammed on one side of the boot, causing excessive pressure on the lock, which can prevent the release mechanism from releasing.
Gently apply downward pressure on the lifted side, then press the boot release button on your remote and try to lift your hand quickly. Timing is the key. You can also get someone to hold the lever up, while you push down on the boot and then release it (boot lid).
Doesn't work :stupid:
I got someone to hold the lever up while i pressed down on the lifted side.. the car went down but the boot didn't, and it's still stuck.
Maybe i should get a locksmith to open it...
  RANDY said:
You haven't mentioned anywhere that you've tried the key? Unless I missed that somewhere.
If the wire is loose, and the lock won't open because of it, then the key will over-ride that anyway.
Yea, you missed it ^_^
The key doesn't fit the lock, so i can't use it.
  shoebox said:
Doesn't work :P
Did you get it?
Did you try the boot release button on your remote while your pushing on the boot lid like Al said?
I agree with Al about pressure on the latching mechanism.
Maybe if you dress up an act just like the Fonz and just give the boot a hit it'll open..... hahahah sorry, jokes man :D
edit: spelling
Edited by KeyMakeR33
thats the easiest way to do it, to remove the rear seat takes 4-5 mins max, then there is a dozen or so 10mm bolts and your into the boot , on once in manually open the boot from the inside , then once u have it open diagnose the issue.
if there is no pressure on the lever in the cabin, it may also be snapped the cable
There is a 'valet' switch that disables the remote release. It's possible that something in the boot has accidentally knocked it to the 'valet' position.
If your key lock is broken, you may need to get a locksmith (as mentioned previously) to break in for you.
  Al said:
Any reason why one side of the boot was higher than the other?
No idea. That side is still like 1/3 a cm higher than the other.. but it still opens, so i'm not really concerned about it. It doesn't look like rain will go in too, so it's okay.
I thought something was stuck too, until today.
I'd guess that the rubber stoppers are taller on one side than the other? The bonnet rubbers are adjustable by winding them in and out, but I didn't think the boot ones were?
Well, if the cable was loose, than my manual method should have worked! (pulling up the side of the carpet, disconnecting the cable, then pulling on it by hand... or ajusting the cable tension)
  Quote
if there is something that could possibly be putting pressure on the boot, i'd go for a quick lap around the block doing some hard stopping and swerving to see if that helps.
Dude! That's a sweet idea! I'm going to try this right now! (I don't have any issues with my boot though?) =-]
Still, that's a great idea for anyone who got something stuck under the boot-arm. I used to get PC's stuck under mine, and you can't shift them over with a coat-hanger!
25th December 2006 @ 14.30
Whilst cleanin the boot out i manage to play with a metal plate inside the boot lid. (not knowing it was the valet switch)
19.30 Whilst travelling down Pitt St in Sydney I managed to get a samell metal fragment in my tyre. (resulting in a flat tyre)
19.31 I realised the boot was not releasing from the boot leaver inside the cabin. No tension at all behind the leaver. Just free air when u pull it up.
19.32 I decided to try the boor lock. It didnt work. The lock is broken. It keeps on making a ticking sound but nothing happens.
19.32: 15 ...I start to swear.
19.34 I try other methods...no good. So I baby it all the way back to Liverpool.
21:00 got home in one piece.
26/12/2006 @01:46 I read this thread and I will try the boot cable under the carpet 1st. So how I go tomorrow to get to the spare.
Why is that Valwt switched linked to the leaver....or is that the safety feature of it or am I totally worng and it is only coincidence???
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
