I guess it had to happen.
The combination of:
"Adequate" power (578 rwhp)
Good torque (HKS 2.8L kit)
Sudden power delivery (GT-RS terbs)
Rebuilt transfer case
Low ratio diff gears (GTS-4 CW&P)
is now resulting in some serious torque steer when coming on boost.
I'm thinking that a front LSD (say 1.5 way) will improve things, however will this adversely affect steering?
"Plan B" may be to adjust how boost and torque split is delivered? I have a dual solenoid boost controller fitted and Duncan's ETS controller available (not fitted yet).
Thoughts and recommendations?
https://www.sau.com.au/forums/topic/146528-serious-torque-steer-in-gt-r/
Hi Gav,
my R32 GTR came with mechanical LSD front and rear so i don't know what make or spec level they are but i've had no probs with torque steer or any other steering problems. It can be a little clunky, through the steering wheel and you can hear it, if taking tight corners and using enough throttle to make the wheels spin. I'm only running about 360 HP thou.
I also have an ETS controller but it can't reduce torque split to the front only make the torque split come on earlier which if yours is the same may make your problem worse.
The LSD up front makes for awesome traction, after warming up the rears at the plex i was able to do 8k limiter launches with very little wheel spin, that's with 285 street tyres all round. Towards the end of the night there was no wheel spin at all but i suspect that was the clutch slipping as the twin plate has a few problems at the moment.
If i had to get new diffs i would probably get the OS Giken super lock diffs, they come with 14 clutch plates per side. Doubt you would be able to get them in the GTS4 ratios thou.
What gearbox you running with all that HP?
You on R&R from Bulgaria at the moment?
cheers
Paul
Hi Gav,
cheers
Paul
Hey Paul
not back until mid Jan, but just some feedback from the tuner and others that have driven the R since the most recent tune and gearbox/tranny case rebuild.
Running an OS cross mission gearset in a rebuilt R33 box.
Won't be buying anything until I've had a chance to look at how it is in real life and perhaps what I can do with boost delivery and/or ATTESSA controller.
Cheers
Gav
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
