Stock R33 Turbo, Rear Hausing Need One Asap
There is a lot of ORs there. But basically my car is experiancing boost creep, as the stock wastgate is too small with all the mods. So i need to have a look at a stock hausing to see how much i can machine out.
Can comone post a pic up of the gate, closed and opened, so i can get an idea how much you can take off.
Alternativaly. if somone has a stock rear hausing, can i buy it or lease it, so that i can machine the hausing and then swap mine over etc.
Also, if anyone has an R32 10psi actuator, can you give me a bell.
As is the car boosts to 10.6psi with the gate fully wired open. The problem is the wastgat starts to open at 7psi and the GIZZMO IBC can not compensate for that much creep.
ALSO how else can i cure boost creep? At the moment, the wastgate pressure tap is taken form the IC pipe, before the TB, like the stock one, if i tap it off the turbo hausing, will that help at all.
Edited by WogsRus
G'day, I have an R32 turbo I split in half and ported the w/gate hole but needs bigger flap made and fitted. I have a piece of stainless to turn one up. Without replacing flat you would be lucky to port 2-3 in diameter out of w/gate outlet hole (going by R32 turbo).
so how much can i port keeping the standard flap, 2-3mm or something like that??? I only need to reduce the creep by 3 psi, but if you can only take out so little, i might just leave it and run with 10.6 psi LOW setting.
i have an r34 turbo lying around somewhere absent the exh wheel, ill dig it out for you as i only wanted the compressor housing :miner:
edit: just putting the r34 housing on "might" cure your problem because i would expect that nissan would have corrected that with the neo turbo?. just a thought
Edited by toffy
HAY toffy, you got that R34 housing somwhere???
yeah mate, ill dig it out for you, its upto you if you wanna buy it or not, i say try it on and if it doesnt fix the problem then port yours and give mine back?, hows that sound? >_<
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
