hey,
just after some quick opinons if i may,
just dropped a rb30det into my r33, the motor was not refreshed at all but the guy who built it said the block and head looked in good nick when he was putting it together (he never actually got it started had to sell up big before he got a chance to due to lack of funds)
on thursday we got it up and running full dyno tune everything seemed in order a bit of valve guide wear blowing smoke when getting off the throttle but when driving on the street i didn't notice it all. did a few 5 min trips from mech but to work that sort of thing during the day, driving really nice and smooth very happy
then on my way home gave it a little hit not to much cos it still hadn't really been running but i'd been told i didn't need to run it in cos it was basically like doing a head gasket since the parts weren't refreshed
next thing i know it loses power for a second and there is white smoke everywhere, but it did clear up but from this point she was blowing smoke out the exhaust as soon as you touched the accelerator and upon stopping it stalled but then fired up straight away and drove a little bit further just to get home blowing a bit of smoke of course.
once home i turned it off and check under the hood saw a whole heap of oil in the corner of the engine bay where the airfilter is also where my bov points, started it up again it fired over and then just stalled tried again same thing, lightly holding down the accelerator just a tad and it started a bit ruff but ran with me gradually lifting off it started to idle, tried a couple of times to get it to start just from turing the key no good,
pulled off intercooler piping i have a link ecu with map and started it up had oil spitting out of the pipe that runs from the turbo and not out of the pipe off the plenum don't know if this means much
left it to sit over night, checked it again in the morning on cold start it kicked over and ran like normal except for white smoke out the exhaust
i've already organised for another turbo and have removed most of the piping ect.
visual inspection of turbo
front turbine intact although has oil sitting in it and a bit of oil leaked onto outside of turbo around bolts for front housing.
so yeah sorry about the novel guys just wanted to make sure i made the full story clear lol what i am worried about now is if it is turbo seal was it just old age 140xxxkm quite possible or could something else have caused it just seems a bit funny that as soon as i put the rb30 in the turbo lets go especially at 5psi
thanks in advance for any input guys
https://www.sau.com.au/forums/topic/146555-turbo-seal-rings-or-something-else/
My 33 did the same thing after a hard run on 10psi. A plume of white smoke tailed me, and the first thing through my head was "how much will this cost". Anyway it turned out I was lucky and melted 4 of the 6 electrodes off my spark plugs.
Cheers
Sumo
Could be a few things.
1. Get the car compression tested to see
if you have two adjacent cylinders that are low in comp.
This means your head gasket is gone.
2. Or check your oil cap for a white milky residue
which also means your head gasket is gone.
3. Any turbo reconditioner will give you a free strip and quote,
so what you could do, is take the turbo off and oil feed and
they will tell you wether the turbo blew the seal or consumed
a valve seal or piston ring.
Cheers,
Bill
A mate of mine had a rb25 turbo on a rb30 in a vl and it killed the turbo so fast, turbo was in good condition when it was put together but after a couple of months it was farked, the 25 turbo is way to small for a rb30 :P
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
