here's my r34. mate took a couple of quick snaps for me. soz if they're too big, first time posting pics
nice pics man, look nuts.
i wish i knew how to take pics like that. i did methods instead of multimedia lOl
Here are some pics I took a few weeks back after a polish and wax. All I can say is....goddamn black looks nice after a good clean. Shame it doesnt stay clean for long though haha.
Pics have my mate's TT soarer in them too....havent have time to shoot the 34 by itself yet. Have since changed the parkers to white...looks heaps better. Last shot is of the autogauges I replaced the stock triple cluster gauges with.
Cara our cars could be twins ! A back to back shot would be awesome... you going to SCS this year? If so i'll be down for sure. We'll do a shoot around then shall we?
Grats on your win too ! The new kit looks awesome.
Edited by Howie
hey everyone!
good news! i won "best vinyl graphics" at adelaide autosalon! here are some pics!
Howie: youre car looks sweet as! lets meet up sometime and take some pics of our cars together!???
wat were u pulln on the dyno
120.1 keep in mind its a non turbo!!!
and photos dont do any justice.............everyone has said bhow it suits the car etc......
but everyone is entitled to their own opinion though!!!!!!
i must say, one of the finer 34s even though a NA.
you go girl lol
im in the process of getting moneis together so i can get bigger cams (not overly big) and valve springs to go with. :( hopefully will get a nice amount of power then............so doesnt make the car seem like its "all show and no go"
not that i really care what people think on that topic
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
