G'day Mick,
hey wayne,
Three questions
Where did u get this from?
How much?
Much quieter than a canon?
Is it more restrictive than the canon?
cheers mick
Where did u get this from?:
Bought & fitted at Kirrawee Mufflers
http://www.kirraweemufflers.com/
How much?:
Both Kirrawee & Best Mufflers quote $500 for this specific model.
I originally ordered the single pipe oval for $400 - they couldnt get me one straight away so they offered me the dual pipe version for the same price :D I'm glad I ended up with the dual pipe, looks much more stock.
Much quieter than a canon?:
Definitely quieter than the cannon I had fitted, or at least has a lot less bass.
I also replaced the large resonator I had for a hot-dog type, this would affect it as well of course.
The new muffler is still fairly loud when the valve is fully open, I had a mate take it for a drive past me and it did sound very nice indeed.
Is it more restrictive than the canon?:
Yes, no question at all - I did go from a 3.5" to 3" for starters. Theres no way it could be as free flowing.
I'd love to put it on a dyno again (was dyno'd only 3 weeks ago) just to see the numbers.
I've done quite a few 0-160 tests since buying the car, and with the new muffler I am honestly hard-pressed to notice any significant difference. I do think that the turbo is spooling up a little higher in the rev range though... I think! Not much in it if it is :D
At least now I feel a lot safer going past the cops, it looks standard and I can turn the bugger down if need be.
Cheers
I would go Apexi N1
its really quiet when you want it to be, but produces a very clean note when you giving it some pin. That said, its not what i would call a loud exhaust at any rpm
Could be an option?
Thats the thing - until you see and hear any given muffler hooked up to the same kind of car as yours, its hard to know what you might find too loud or not loud enough.
I've been having evil thoughts about constructing some kind of solenoid activated valve that simply diverts/opens up the pipe before the resonator :D I'm sure I'm not the first to have thought of that though! Would be nice to have for the times when you really want maximum performance...
Got my twin dump pipe from these guys... The said that there twin tips have same flow as there cannon and look at there power figures...
Good quality and price give them a look http://www.cesracing.com.au/products/
agreed, R spec that is one nice lookn r34.
theres always something about red cars lol.
i recommend u get the r34 gtr diffuser on the front aswell, because it sitll looks a little short in size.
and we all no the wing has to go =]
how much did the front conversion set u back? did u get it from powerplay?
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
