just an update guys
some shocking pics but here ya go
car made 300rwkw at 16psi last nite, will be pumping about 20psi and see how that goes, might even go for 25-28psi at the end =D
Well done, is that still on stock cams by any chance?
I'd like to reach 300RWKW and then call it a day (famous last words, lol) and would be very pleased if I can achieve that without resorting to new cams while at the same time not over-stressing the engine. Might be a bit of a big ask though...
get rb30 then
my car hit 300kw at 16psi with standard cams =]
NICE Freakin work mate!!! Details details..!
yeh thanks....i was pumped wen the boot screen came up..... :unsure:
theres more pics here
http://www.skylinesaustralia.com/forums/R3...tt-t221016.html
but only just hooked it up.....so havnt got alot of pics....but ill add more in there tm
:P
yours?
seen an EXACT same 34 here the other day :P
ooh really?
thats good to seee!
That car is for losers... losers called Sheng with nice cars :P
But ya, tis his, tis nice :laugh:
Haha hey albert, did you take your keys with you to holsworthy? :unsure: leave em with your dad?
LOL.. keys stayed home, in my safe mate, dont you worry :(
ps you forgot to mention babe :P
Runs to the garage..
Ok that is most definately THE hottest GTT I've seen on SAU. Congrats mate! I enviez ya. That's the top secret bar hey .. what about that bonnet? I've been toying with the idea of getting a bonnet but don't wanna be a defect-magnet witha CF bonnet (they're illegal aren't they??)
Hey mate cheers :D
yeah its a top secret bar, the bonnet is a gunine c-west, and yes there are illegal, unless its engineered.
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
