just an update guys
some shocking pics but here ya go
car made 300rwkw at 16psi last nite, will be pumping about 20psi and see how that goes, might even go for 25-28psi at the end =D
Well done, is that still on stock cams by any chance?
I'd like to reach 300RWKW and then call it a day (famous last words, lol) and would be very pleased if I can achieve that without resorting to new cams while at the same time not over-stressing the engine. Might be a bit of a big ask though...
get rb30 then
my car hit 300kw at 16psi with standard cams =]
NICE Freakin work mate!!! Details details..!
yeh thanks....i was pumped wen the boot screen came up..... :unsure:
theres more pics here
http://www.skylinesaustralia.com/forums/R3...tt-t221016.html
but only just hooked it up.....so havnt got alot of pics....but ill add more in there tm
:P
yours?
seen an EXACT same 34 here the other day :P
ooh really?
thats good to seee!
That car is for losers... losers called Sheng with nice cars :P
But ya, tis his, tis nice :laugh:
Haha hey albert, did you take your keys with you to holsworthy? :unsure: leave em with your dad?
LOL.. keys stayed home, in my safe mate, dont you worry :(
ps you forgot to mention babe :P
Runs to the garage..
Ok that is most definately THE hottest GTT I've seen on SAU. Congrats mate! I enviez ya. That's the top secret bar hey .. what about that bonnet? I've been toying with the idea of getting a bonnet but don't wanna be a defect-magnet witha CF bonnet (they're illegal aren't they??)
Hey mate cheers :D
yeah its a top secret bar, the bonnet is a gunine c-west, and yes there are illegal, unless its engineered.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
