Took a few pics yesterday of this beast :O
What a beautiful car!! The photo shoot was a spur of the moment thing.
No sun when we arrived, then the sun came out of know where and then it started to rain.
Then my lens got a little wet and photos came blured, as i didnt have my cleaning kit..
To top it off my brand new circ. polarizing filter broke the day before :)
Im no professional and far from it - just thought i add that line in hahahahh
oh still stock kit lens ;)
Anyways here are some shots:
Edited by siddr20
nice stuff!!!.. white is a biatch to get right. use a flash in daylight to get the wheels to pop a bit more then you can soften the exposure so it doesnt blow out.
I know :P
If i wasnt going to europe in two weeks i would have had a better lens and few external flashes by now..
but all i got is just a body and stock kit lens :)
one day sigh.. hahah
Edited by siddr20
Aww dodgy fake motion blur Sid, Your better than that :P
lovely looking car though
I know.. i just had to do it.. it was distracting me soo much!!
i think thats gt-r's for sale around 65k??
very nice pics btw.
Yup its for sale if anyone is keen :)
very clean car!!
Nice pics. And don't knock the nifty fifty it's a great little lens...
Yeah I noticed the dodge motion blur too... 1/640th of a second doesn't allow much motion blur :D
Regardless, they're nice pics...wouldn't mind gettin my hands on some high res copies...
hahahha i know :P
The background was distracting me quite a lot :(
oh i love me 50mm lens and im by no means knocking it..
I think its really a good time i move on from the stock 18-55mm lens.. Its good, but i need something better now!!
Edited by siddr20
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
