Ricca, you have to bring that beast out before you sell it!! I really want to see this beast in the flesh!
I will just waiting to get my Licsene back lol
19TH DEC!!!! AFTER that u will see it everywhere lol
Not many GTRs in red around.
However, in that last pic. I really dont like the retro fitted projector headlight.
I would much prefer the stock headlight
It´s a BMW color - Imola Red 2 :)
I liked it a lot when I saw some M3 on the Nürburgring, so I choose that color instead of Millennium Jade or Silica Breath for my respray (car was bought with major body damage).
Used to be the first street legal R34 GTR in Germany :P
I just had the projector headlights fittet for the "TÜV", where every 2 years they check if your car still meets requirements blabla ;)
Usually I have the Xenon lights in :)
I hope to get the car ready, soon. Should be the meanest GTR in Germany, at least I planned it like that. Twin GT303s 0.86 A/R should help with that on top of a stroker :(
I just hope it´l survive top-speed huntings on the German Autobahn with all those Porsche and AMG around me...the Autobahn usually kills all tuned japanese cars that were not built for the job...much easier to get a car quick on the quarter mile than reliable on the Autobahn... :P
BTW notice my license plate *g*
S for my town (Stuttgart) and then R34 Model - usually you can´t get those short plates here...no individual ones around like in UK or somewhere else! You always got to have your town first, then letters and numbers...
Edited by AndyStuttgart
Nice... I usually hate those wheels but they suit the car / colour very well.
Thanks Stan,
It look me a long time to finally decide on a set of wheels, but i think my choice complimented the car.
Factory colour too, the colour i always wanted, Dark Blue Pearl, i've yet to see it in the flesh on another R34, but i know there are some around.
Dallas.
Thanks Stan,
Dallas.
The colour looks really good on your car. Its a shame that more r34's werent painted in the same hue
hey dude, got a Spec-R i'm trying to decide where to mount, and that looks like a perfect spot. Was it much drama to fit the BC there?
Hey,
I just cut popped out the two spaces (fog lights and a blank) and cut in between the two with a hacksaw, then smoothed it a little with some sandpaper, not that you could of noticed if i didnt, and it slotted right in there, it's a tight fit, but that ensures it wont go anywhere.
You don't even need to support it on the back, it just sits there, i can sit there and push buttons all day long and it goes nowhere.
Goodluck.
Dallas
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
