R34s...please!
NS2500
Dirtgarage - So it's worth it, then? Haha. Oh well, too late now.
Matt - You're a bad influence. Stop it. :)
Thanks, everyone, it's a dream come true.
Edited by Huy
Bonnet is on the best that it can be... the RB30 conversion has set the overall height of the engine higher by 40mm and the front of it is fouling on the bonnet support (even with heat shielding off). Without lowering the subframe, cutting the supports, the only way we could achieve a closed bonnet was to space it up.
It's a bit unsightly... but then again the car was never built to be 'pretty'. Does a good job at venting away hot air though as there is now a clear route that heat can escape from under there.
Maybe later I'll get some custom guard moulds made up to blend up to the top of the bonnet (removing the gap). Will just make the front look mega-beefy.
Haha, you told me to show it off, Alex.
Getting it tuned on Friday. Considering how hard it already goes, it should be quite fun!
I want the LMGT4s, but obviously everything is so expensive at the moment. I may have to fork out for a set.
Thanks, fellas.
So, where to get the LMGT4s? I looked on Nengun, for 19x10.5, +15, it equates to roughly $4500. I'd be happy to pay that, though my last dealing with them wasn't the best. Anyone care to point me the right direction?
