car is looking good vietboi, what size rims are they & what ride height is it? (mm front & rear)
rim size are 18inchs, 18x8.5 fronts and 18x9.5 rears,
ride height, not sure but i cant fit any fingers in the gap from the top of the wheel to the arch
and with the rears can only just fit one finger in.
hey dori34, do you have any pictures of your front bumper? like the full thing?
Edited by viet_boi
ohh okay, ride height looks good :)
i want to raise mine up a bit cause its too bumpy atm and its annoying.
best pic i could find.
^ i wanted r33 gtr rims for my 34 but was told it wont look as good until i saw those pics, i wished i got them lol.
heres pics of mine; getting impul side skirts soon
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
