R34s...please!
NS2500
Do 32.4's count ?
my Pig
The Key to happiness
what happens when you forget your bonnet pins
The new wing
Got it off a guy in Melbourne, not sure of brand but he got it in japan a couple of years ago.
I've never seen one for a 4 door before hence why i grabbed it.
pretty sure 4dr and 2dr boots are same... size for fitting anyway
Never tried fitting a 2dr boot but pretty sure there different sizes on the bit that says "skyline" as well as across the top... but don't quote me. As well the rear lights are different shape around the boot.
stickers arent a mod. very nice car though, if only you didnt have the ghey factory option wing
+1 on the wing, they really stand out , i personally dont understand how Nissan thought this looks appealing to people, maybe its just me.
hey nice 34 though all the same.
cheers,
David
Hey i like your rims Ash, nice indeed,Black really looks tough
Grant your car always comes up looking so nice in all the pics ive seen
Thanks David. Its just amazing the difference a great camera makes. My mate took that shot with a 50D. The sharpness of it makes anything look good :P
hey guys,
just thought i'd post a quick few up... have a few more but they're too big to load at the moment so when i get the chance i will but yeah here's my car from a few photos i've taken over the weekend
hope you guys like, cheers
Andrew
and a couple more...
and i do apologize for the lighting...
there wasn't enough in the showroom (well we got a crap location anyway)
and by the time we could grab some pictures after we left it was getting dark so i'll be taking some pro ones later on in the week in a really nice scenic area with no reflections etc...
hopefully it stays this clean bahaha
Edited by hoony
These photos where taken when i put sitckers on my side door of the car.. didnt go well so i took em off and kept the nismo one on the right. The OTR sticker on the back rear window has been changed to a nismo sticker. The rear window now has a nismo decal running across it, changed a bit since that photo. But looks way better than before i will post up new pics soon. :rolleyes:
    • Acostal came through with a new bracket which should free up some adjustment arm and hit my target of -3.7° camber and 7° caster. (old black, New silver) fitted up and you can see how much shorter it makes the relative length of the caster rod as well as swinging it slightly to free up some misalignment in the bearing   with Caster maxed out short this is how the wheel sits on the car in the air While I was at it, I pulled the wheels off the car to inspect the suspension and noticed this lovely gash. A pity becasue these tyres, while on wear bars, would have had at least one more dry grip day in them. Have a set of AD09 to try out next which I expect will be slower than the CR-s or AR-1 were but better in the rain with a longer life?
    • Oooohhh man did not bloody know that, that's amazing thanks heaps for sharing mate, bookmarked it!
    • In case you haven't come across it, there's also https://nissan.epc-data.com/ Go by VIN or drill down into your specific model and year and it'll have references for pretty much all the OEM parts. In very similar diagrams. Linked against amayama as well for ordering. Though they can be a bit slow and can be better to search around to get the parts locally.
    • Just in case anyone finds this in the future, here's a diagram sent to me by Nissan to identify these hoses. I ended up finding them through EFI Solutions though because Nissan reckons they need to order it from Japan, with a total cost of approx $110 inc. So it as cheaper with EFI anyway. https://www.efisolutions.com.au/blow-by-hose-rb25det-r33-wc34-c34-c35 https://www.efisolutions.com.au/blow-by-rocker-cover-hose-rb25-r33-wc34-c34-c35
    • This is an older post of mine but I just thought I should update it and explain what the problem was. Long story short the friction plates were below their service limit. New they are around 4mm, and service limit is (according to OSG) 3.5mm In addition the crank seal gasket wasn't sealing 100% anymore and that led to an oily clutch. Not sure what came first and why the clutch was worn after just 10,000km .. but all good now. OSG refresh kit via Nengun
