pretty sure 4dr and 2dr boots are same... size for fitting anyway
Never tried fitting a 2dr boot but pretty sure there different sizes on the bit that says "skyline" as well as across the top... but don't quote me. As well the rear lights are different shape around the boot.
stickers arent a mod. very nice car though, if only you didnt have the ghey factory option wing
+1 on the wing, they really stand out , i personally dont understand how Nissan thought this looks appealing to people, maybe its just me.
hey nice 34 though all the same.
cheers,
David
hey guys,
just thought i'd post a quick few up... have a few more but they're too big to load at the moment so when i get the chance i will but yeah here's my car from a few photos i've taken over the weekend
hope you guys like, cheers
Andrew
and a couple more...
and i do apologize for the lighting...
there wasn't enough in the showroom (well we got a crap location anyway)
and by the time we could grab some pictures after we left it was getting dark so i'll be taking some pro ones later on in the week in a really nice scenic area with no reflections etc...
hopefully it stays this clean bahaha
Edited by hoony
These photos where taken when i put sitckers on my side door of the car.. didnt go well so i took em off and kept the nismo one on the right. The OTR sticker on the back rear window has been changed to a nismo sticker. The rear window now has a nismo decal running across it, changed a bit since that photo. But looks way better than before i will post up new pics soon. :rolleyes:
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
    • this is the reason we have more than one child right?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
