Heres my new ride... been waiting till i get her detailed and have a digital camera to use rather then my iphone but can't wait any longer so here are some pics will post more when she is clean and have a proper camera lol.
If the pics are upside down i apologies i did rotate them and save them but for some reason it does not always work :D
^ hahah, fellow Detail Addition members... unite!
yes, you need to ditch that nasty chamois/sponge looking thing and get some Aquatouch MF wash mitts. www.finalinspection.com.au - EVERYTHING you need to look after the car properly is there.
Everyones cars look sick! I'll admit i'm getting a little jealous seeing all those P plates seeing as i went through highschool and uni before i could get my car :P + loan! lol
Its pretty stock right now though, only had her a couple of months, got a FMIC on the way and changing the exhaust after that. I wanted a black one but there weren't any around when i was buying, now there are two :ermm:
Haha. At least someone on here won't give me funny looks for using 3 MF mitts (purple ones at that!), two waffle weaves and way too many mf cloths for one wash! Must admit, it's a mighty effort washing a black car..
Car looks like a beast, Bakes. I think the young fella is paying attention to the tailights. Important part of a Skyline. :P
here's my ride today after a good few hours of cleaning/waxing
tried to take a couple shots to show off the glossyness
got a bit of scrape on the bottom left of the front lip, you guys reckon this is coverable by touch up paint if i go to a specialist to get some mixed up?
post-63813-1245512536_thumb.jpg post-63813-1245512580_thumb.jpg post-63813-1245512594_thumb.jpg post-63813-1245512609_thumb.jpg post-63813-1245512621_thumb.jpg
Daniel,
sent you a PM couple of days ago
Cheers
Michael
gersfan!
i looked into buying that car i think, from autoworx. Or a similar one, cos alistair was the only one selling decent R34s but when i enquired about some of them the price was higher than i was willing to go! and he refused to drop it...and now hes dropped them anyway but i bought a white R34 now.
But i still love my car, its just not what i was planning on.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
