  (OO)SKYLINE(OO) said:
Hmm... Really, must be a "Nur" item...
he said his is a V-spec not a Nur, besides Nur is based off V-spec II (or M spec), diffuser would be same same, should have fins pretty sure
  RusH_ said:
nice you got the z-tune skirts and pods, mind sharing where you got and how much, i plan on doing the same?
and was the fitment good, or did it require modifying?
+1 Please.
Also, would you possibly know how high the skirt is, as i've got aftermarket skirts already and not sure if these would make it too low.
Cheers
  Owgasm said:
+1 Please.
Cheers
They only fit onto the stock side skirts. So you'll need to remove your aftermarket skirts
  stenve said:
also +1 :P
I got them unfitted and unpainted from a private seller over here in Perth because he didn't end up wanting them in the end. I believe he got them from JSAI but last I heard, JSAI isn't doing them anymore.
And in regards to fitment, no modification was needed and they came out extremely well! Although it all comes down to who you get to paint it and fit it for you.
  viet_boi said:
Nice flaring, can't really see it much but the last pic you can see abit and looks good.
and crack paint??
They repainted them..
Kinda hard to see in pics..
Edited by 83CKS
  Dani Boi said:
and he's not talking about the car!
Nice rim's, DO WANT.
:domokun:
I know she has a nice rear!
Looks nice Beck!
I think you could spacer out a few more mm in the rear though...
Put a spacer in :)
Hey Chris glad to see ur happy with the skirts, its good to see them on! Yeh i got them from Josh (JSAI). I dont know if he's doing anything anymore, i heard a lot of crap about him after i had those sent over. I had no problems at all with him tho.
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
