No mods done to any of the guards. Doesn't scrub either :ermm: ..
Domo protects my car while while I'm at uni all day lol
Btw whats poke?
I don't think that +12s would be able to fit the front of a GTT without guard work.
Other GTT owners? example of your offset/pics as well.
Poke, like said, rims poking out of the guards.
Domo does the same for me. Angry little F*cker.
Looks good buds.
I wish i had the balls do do that, what other plans do u have. I think that could look awesome with right wheels, suspension, smoked indicators maybe.. i like it :D
lol,
In the next few weeks, ill most likely be going gloss black Rota GTR's 18x?? (undecided yet)
Smoked indicators all around are already on the way from japland.
And then possibly a new kit depending on funds at the time.
My taxi, completely stock:
Damn that thing is high!! Slam it to the weeds :thumbsup:
Done, about time too!
Apologies for the photo quality, we've been a bit short of sunlight recently...
Cheers
Edited by V28VX37
Looks good buds.
Damo_R34 has same offset and rims as me but in black. Only problem he had was the rear guard making 'gentle love' to the tyres over bumpy roads.. perhaps his car is sitting lower then mine
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
