That looks so tough!
Might actually take off my rear wing lol
your car looks just right the way it is dude, dont do it. unless your planning on slamming it...
What happened to the front bar R-Spec?
Went back to oem?
yeah didnt like the fibreglass and got over the gtr front look. way too overdone IMO
Wicked stance there R-Spec!
thanks mate :)
  • 3 weeks later...
  • 4 weeks later...
Man I'm loving this thread, it gives me a great idea on how i want my final car to look like!!
Keeps em coming guys, their fantastic pieces of machinery!
I know I shouldn't...
But for you Blazen...
How about 2 for 1?
Springs/susp'n on the blue one since arrival have lowered the car to proper height.
Is Geoff Wheeler still in the end workshop there at Valley Heights? Used to annoy the pants off him when I had my old Triumph...
Edited by Daleo
Hi Dale,
I somehow knew Geoff from church years ago when he was in cahoots with the headmaster of J. Wycliffe HS and started off a Family Church somewhere.
I actually didn't know him well except that he had a front-end + alignment + steering workshop in one of these bays - top one I think.
He seemed very easy to get along with.
Hi Dale,
Fair enough, he used to have an amazing collection of Lotus 7's (used to punt one around Catalinaph34r.gif) and Lotus Cortina's, was a wealth of knowledge with anything BMC.worship.gifHelped me out innumerable times as an apprentice (no money), but haven't crossed paths with him for many years...
Funny the things you remember when you see a picture.
I digress, apologies for offtopic, back to the 34's!
Edited by Daleo
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
