R34s...please!
NS2500
But your post still prompted me to think,...
it must be a bit difficult to find what rims would suit Silica Breath...
I'm guessing that gold, titanium, chrome, white or even black rims might not suit that coloured car?
Perhaps just matt silver - hmmm, maybe bronze? Thoughts?
i'd just go silver wheels. anything else would look weird.
i know it's off topic but here's a Silica Breath C10 to illustrate the perfectness of silver wheels on silica breathe
again, sorry for non-34 post
Edited by alex182
...seems to be so!
Haha... I like it though, if I had an M-spec I'd definitely like it in that colour.
Reminds me a bit of the Diablo 6.0 VT colour "Oro Elios" which was a special "final edition" colour, kind of like the M-spec is to the R34.
Weirdly, the colour also kind of reminds me of the old Nokia 8850 Gold, which used to be the phone-to-have, back in the day...
Does anyone know why KSR removed the vented bonnet?
Thanks to "MadKent" from the recent SAU Wisemans Ferry Cruise
Edited by lanky71
For a second there I thought you thought that this car is KSR... Whoops
If this is yours Drew, I've always liked the look of your car; so clean and tasteful mate. :thumbsup:
Matt
Matt
hey matt, yep its mine. Thank you, thats the same thing everyone who comments on the car says, its clean.
He painted the carbon bits white, its still there lol, just not visible from the photo
Ah ok, I liked it with the carbon bits unpainted.. almost made me want to replace my bonnet with that style just to be able to do it - leave the vents unpainted lol
Either way its still an amazing looking car.
Nothing compared to some of the beasts posted earlier but heres my baby :)
R34 GTR's look tough as stock. I would just lower it slightly and chuck some spacers on, say, 20mm and you got a tough looking guy already.
Heck, buy my spacers: Quality 20Mm Spacers Cheap For Quick Sale! - Skylines Australia
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
