R34s...please!
NS2500
^^ TE37 SL 19 x 10.5 +12, but from memory the previous owner of that car ran a spacer at the rears for a bit of poke.
noriyaro_rgf_r34_gt-r_nur_002.jpg?w=700
If you went the TE37 SL or a Black set of Nismo LMGT4's, it'd give you the tough look.
Agree on the black (GT500 centrelock-look) LMGT4 suggestion above!!
Tada! Dodgy photoshop with RE30 clubsports:
Edit: Actually, unfortunately AFAIK the clubsports are only available in a maximum of 18". But you can still get some 19" RE30s, fomula silver is the best colour IMO (similar to the clubsports) as opposed to the chrome silver, white or bronze for RE30s
Edited by God_speed
Jade on Bronze isn't the best combination in my opinion.
Black/White/Bayside Blue on Bronze is best.
People tell you to be different but.. its hard to be different when the common way is the common way because it looks better.
I have gt500s hehe :yucky: and a few other thousand wheels too :( its bad.
Welldone on the purchase!
Just to clarify, is the RB26 stroked to a 2.8lt along with aftermarket turbos?
I'd stick to the Nismo LMGT4 wheels you have and in that Bronze colour too! But just go wider and more aggressive offset.
Millennium Jade and Bronze give you the clean look.
And it being a Nur (bit more of a collectors item) I'd keep the Nissan / Nismo theme going through it.
If it was me, I'd get the same wheels / colour but go for a 18 x 10.5 +15 or +12 and test fit that.
Yep its stroked to a 2.8 but still has n1 turbos. Super responsive!
Yeah 10.5 is the go! Black LMGT4's are unreal! Thanks for the pic that looks amazing!
WOW Matt that looks freaken unreal!!! Awesome photo shop skills man! Thanks for that! I don't know what looks better lol LM's or RE30? Love the colour though. I would prefer 18" for track, mix it up with the other set for street as well. It would be like deciding on what shoes to wear when you go out haha I think im leaning more towards the RE30's there is just something different about it
Thanks Marko
and no worries I enjoy doing that sort of stuff. :)
The RE's are very light weight as well. When I weighed my 18x9.5 +15 ones they were about 8kg each.
Simon (N11smo) is selling the set that he bought off me; but sounds like you'd want something slightly wider.
Ah I see.
Yeah for sure, always love a super responsive GTR :thumbsup:
All good, post pic of new wheels when you get them :D
My one has got the Te37SL's 19x10.5+22. Will post an updated pic when I got a chance.
I am sure I have a pic of your car but I will leave it to you to post :P
upload to photobucket/flickr or something, then when you go to post, at the top where "bold" and "italics" are, to the right you'll see an "image" button. paste your photos URL there and done.
i was stuck to hope this helps
http://www.skylinesaustralia.com/forums/index.php?app=members&module=messaging&section=view&do=showConversation&topicID=1104526&msgID=__firstUnread__
Finally uploaded a couple. Not the best quality but oh well. When I got my car lowered, I had to get modified rear camber bushes and run as much positive camber due to the coilovers external oil canisters hitting the inner rim due to the width and offset of the rim. The guys at centreline suspension did a great job with fine tuning the coilovers and adjusting my cusco negative upper arms.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
