R34s...please!
NS2500
Looks awesome guys!!
Nathan I love the rims mate! What sizes are they?
They are 19x10.5 +22 offset. There's also the +12 offset option too. Tyres are pirelli p-zero rosso 275/30
Nath, car looks sweeeetttt. Looking forward to seeing it in person hopefully soon :-)
Hey Tony, I haven't been to a meet in such a long time...So busy lately with functions.
can u get away with running +12 offset on a 34 without rolling the guards?
Terry's N1 has 18" x 10.5 +12 LMGT4s, they are fine and guards are stock (but have 265 width tyres so there's some stretch). If you had 20"s then you'd probably be forced to dial in some more neg camber or go a higher offset.
I run 275/30 on a 19x10.5 +12.. but i'm sort of a in a different category.
At one point I spaced the rears out with a 15mm spacer. On bumpy roads it will hit the guard and I had little lines in the tyre from the cut.
With a 275 tyre you will get away with it. My old tyres with the same rims were 285/35 and had so many problems. As what simson said, I had MANY of those little lines to the point it was conisidered a safety issue. Overall, you can go quite aggressive on offset. One interesting thing I saw at Racepace was a blue 34GTR with 20x10.5 (ADV.1 5.1spec) 285/25 and had no issues at all. I'm pretty sure it was those wheels.
Finally uploaded a couple. Not the best quality but oh well. When I got my car lowered, I had to get modified rear camber bushes and run as much positive camber due to the coilovers external oil canisters hitting the inner rim due to the width and offset of the rim. The guys at centreline suspension did a great job with fine tuning the coilovers and adjusting my cusco negative upper arms.
Car is absolutely beautiful mate imo that black thing on the bumper ruins it though, all personal preference though. Definately one of the nicest 34's ive seen!
Yep my car has had 20" x 10.5 with 285s on with no issues, but the offset was +20 or thereabouts.
I'm running a +2 on a 9.5" wheel with very minimal rubbing against the liners. I did remove the ones at the bumper side to give more clearence
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
